need4speed Posted September 3, 2010 Share Posted September 3, 2010 As above. Ive just fitted the rear tub onto my chassis, however there is a gap of roughly 5/8" between the top of the crossmember and the tub. Its lined up correctly as all the bolts are in.. At first i thought maybe my TD5 chassis wasnt 100% compatible with my rear tub. Then i noticed from the 110 parts book that there seems to be some sort of filler bracket (Part No 330271) Can anyone advise if this is the part i need to get in order to fill the gap i have? I'll take a pic over weekend to let folks see what i mean. Phil Quote Link to comment Share on other sites More sharing options...
need4speed Posted September 3, 2010 Author Share Posted September 3, 2010 Ok. So a friend has just told me that 330271 (superceded by AQR710020) is actually the strip of metal that the bolts holding the back of the tub go into. Therefore its not that part i need as my tub is bolted already. Im at a loss... Quote Link to comment Share on other sites More sharing options...
landrover598 Posted September 3, 2010 Share Posted September 3, 2010 Is there a gap between the crossmember and the tub all the way across, or just in the middle section where the door / tailgate is, not at the rear light pannels ? Quote Link to comment Share on other sites More sharing options...
need4speed Posted September 3, 2010 Author Share Posted September 3, 2010 No the gap is just in the centre section. Not where the lights are.. Is that normal for some? Phil Quote Link to comment Share on other sites More sharing options...
landrover598 Posted September 3, 2010 Share Posted September 3, 2010 yup Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 3, 2010 Share Posted September 3, 2010 Show us a pic, but this sounds normal. Each side is slightly lower than the centre section. The bit beneath the door sits about 5mm higher than the sides. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted September 3, 2010 Share Posted September 3, 2010 Something like this Phil ?? Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted September 3, 2010 Share Posted September 3, 2010 No the gap is just in the centre section. Not where the lights are.. Is that normal for some? Phil Thats just how mine is Quote Link to comment Share on other sites More sharing options...
need4speed Posted September 4, 2010 Author Share Posted September 4, 2010 Thanks for the pic David. Thats how mine is except i believe the gap on mine seems a bit bigger. Dont suppose it matters much so long as all the bolts are in.... Quote Link to comment Share on other sites More sharing options...
