tweetyduck Posted September 29, 2010 Share Posted September 29, 2010 I have 130 springs on the back of my 110 and it sits high when empty. The fronts are standard. Its never been loaded as per my planned trip although i put about 50 breeze blocks in the back and it went down about 2cm. Questions are should i put +2 inch shocks on? Do they close to the same length and just open longer? I'm looking at putting on some Terrafirma Big Bore on and keeping my Armstrong (£10 per corner) as spares. The Terrafirmas come in 2 inch and standard. I have standard length hoses. Quote Link to comment Share on other sites More sharing options...
Adam001 Posted September 29, 2010 Share Posted September 29, 2010 Depends what you want, only reason you should need +2 shocks is if your shocks are limiting axle articulation and you actually want more articulation. I have heavy duty +2 springs all round with +2 shocks and I get lots of flex which is annoying as I don't have dislocation cones Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 29, 2010 Share Posted September 29, 2010 I've got big bore's on my rig, they're frickin huge compared to the ones I took off, I have kinda of 2 inch lift.. I dropped the mountings by 2 inches as well... To be honest, I wish the truck never had the lift (I didn't do it) but to replace all the cranked rad arms etc was heaps more expensive than it was just to run with how it was set up and actually make it all work. Can't tell you how they run as I've not actually driven the truck since intalling them!! give me a week and hopefully I'll be back on the road! Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Author Share Posted September 29, 2010 OK thanks. Still open for debate then. Since my bumps are ~5 inches up on the rear i think my current shocks are at the end of travel or nearly which is why i'm asking. Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 29, 2010 Share Posted September 29, 2010 OK thanks. Still open for debate then. Since my bumps are ~5 inches up on the rear i think my current shocks are at the end of travel or nearly which is why i'm asking. One way to make up the differnce is to invest in some lowered chassis anchor points, the old shocks I took off where actually operating at the extended length (not good) so I did both, longer shock travel and lowered mounts, maybe its now a bit too much, so might have to put the old shock mounts back on. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Author Share Posted September 29, 2010 so you think the extended shocks should be OK as i'm riding high ? once i'm loaded they should still be OK, right ? Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 29, 2010 Share Posted September 29, 2010 so you think the extended shocks should be OK as i'm riding high ? once i'm loaded they should still be OK, right ? Yeah, the new shocks should stop you "topping out", but still give you plenty of travel when loaded. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 If you fit lower mounts AND longer shocks, surely you will bottom out the shock before you hit the bump stops? Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Author Share Posted September 29, 2010 I was just going for longer shocks.....open to any advice Please explain this like i have no clue..........i don't Quote Link to comment Share on other sites More sharing options...
Aragorn Posted September 29, 2010 Share Posted September 29, 2010 I think even with longer shocks the same thing could happen. If the shock is 2" longer, then presumably the fully closed length is longer as well, so you may end up in the situation where the shock can bottom out before the axle hits the bump stops. I suspect theres some room for error, so maybe +2 shocks on their own will be fine. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted September 29, 2010 Author Share Posted September 29, 2010 I could fit taller bumps i supose once i know what its like loaded. I really need to find the closed and open lengths and work it out. Nothings ever easy........ Quote Link to comment Share on other sites More sharing options...
Maverik Posted September 29, 2010 Share Posted September 29, 2010 ... Quote Link to comment Share on other sites More sharing options...
