Shaggy Posted October 2, 2010 Share Posted October 2, 2010 Hello, I have a converted Diesel to V6 Landrover 90 that (touch wood) although is a bit beaten up has never let me down. Off late though the front left main beam and the rear right light's do not work. the rear right brake light does not work either. All other lights, inc the side lights and Fogs work. I am a dufus when it comes to cars so any advice would be gratefully received. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 2, 2010 Share Posted October 2, 2010 Which V6 has it got in it then? (Not related to lights, just being nosey) If several things are affected, it's usually a dodgy ground connection. Follow all the black wires from the non-working bits back towards the battery - a lot of stuff grounds to the body nearby, and connections can corrode over time. Also check fuses and fusebox, if it's old-style fuses they can get a bit loose in the holder and get unreliable. Quote Link to comment Share on other sites More sharing options...
western Posted October 2, 2010 Share Posted October 2, 2010 clean the fuse clips too, if it's a glass fuse type, the clips get tarnished & cannot get a good clean contact. Quote Link to comment Share on other sites More sharing options...
Shaggy Posted October 3, 2010 Author Share Posted October 3, 2010 Thanks for the replies chaps. I will take a look. its an Essex V6 conversion, the wiring is all over the place though Quote Link to comment Share on other sites More sharing options...
