loud howling under car
steerngo
 Share
Hi I have a 1999 diesel freelander, I replaced the viscose coupling (recon unit)and the bearings (Brit part) aprox 18 months ago. things have never been quiet. But just lateley rumbling has got louder, and then the otherday I started getting a loud howling noise.I can feal some vibration on the prop tunnel. I am now woundering if the bearings, coupling, or even the rear diff are faulty. Ive also noted ther is no way to grease the bearings! or have I missed something . Only used to series models and range rovers, Grease nips everywhere. None on a freelander( backward step I think) HELP PLEASE
ken
Hi Ken
Have a gander round the site and search for Britpart related topics. You will find that their gear is not held in high regard. :rolleyes:
It may involve a bigger initial outlay, but genuine spec goods or even proper branded LR goods will almost definately save you money, time and aggravation in the long run.
Dan ;)
Hi Ken
Dan ;)
thanks Dan Iam realiseing this as I also found a worn engine stabaliser, all put on the motor aprox 18months ago. You would think parts from a company supplying parts to the MOD and others, thay would be spot on!
ken
  • 4 weeks later...
 Share
