Arbman Al Posted October 9, 2010 Share Posted October 9, 2010 I am planning on putting a TD5 engine in my 130 to replace the knackered 300tdi. I need a TD5 gearbox.... I have a dead 300tdi R380 I can rebuild (bearings went big time) and put a td5 bell housing and mainshaft in it. Or I can get a reconditioned td5 gearbox, but will my transferbox fit straight on? The cost of a rebuild kit + bellhousing and main shaft is not far off the price of a recon unit. What would you do? Al Quote Link to comment Share on other sites More sharing options...
ashtrans Posted October 9, 2010 Share Posted October 9, 2010 I am planning on putting a TD5 engine in my 130 to replace the knackered 300tdi. I need a TD5 gearbox.... I have a dead 300tdi R380 I can rebuild (bearings went big time) and put a td5 bell housing and mainshaft in it. Or I can get a reconditioned td5 gearbox, but will my transferbox fit straight on? The cost of a rebuild kit + bellhousing and main shaft is not far off the price of a recon unit. What would you do? Al most 300 tdi R 380 are suffix J, if yours is then the TD5 pinion will not fit as all TD5's are either a suffix K or L and the pinion bearings are different, Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted October 9, 2010 Author Share Posted October 9, 2010 Does that mean my transfer box won't fit, or I need to change more bits? Quote Link to comment Share on other sites More sharing options...
western Posted October 9, 2010 Share Posted October 9, 2010 transfer box should fit straight on. Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted October 9, 2010 Author Share Posted October 9, 2010 Thanks for replies. I find all these different Landy gearboxes confusing :? What bits do I need to buy/change to get a 300tdi R380 suffix J to fit to a TD5 engine? Thanks...Al Quote Link to comment Share on other sites More sharing options...
Bush65 Posted October 9, 2010 Share Posted October 9, 2010 Thanks for replies. I find all these different Landy gearboxes confusing :? What bits do I need to buy/change to get a 300tdi R380 suffix J to fit to a TD5 engine? Thanks...Al I think Dave has answered that for you. I took his reply to be a black and white statement that the TD5 shaft can't be fitted to a suffix J box - if it was possible he would have said so. I recall from information on the Ashcroft web site that the bearings were increased in size for suffix K & L, so presume from Dave's post above that the bearing OD and ID are increased in the suffix K & L boxes. Then the bore in the suffix J housing would not accept the larger bearing required for the TD5 pinion shaft. Quote Link to comment Share on other sites More sharing options...
Arbman Al Posted October 10, 2010 Author Share Posted October 10, 2010 Ah, I get it now. Sorry being thick I'm a tree surgeon not a mechanic lol Quote Link to comment Share on other sites More sharing options...
