tweetyduck Posted October 20, 2010 Share Posted October 20, 2010 I understand you can get rubber spring isolators for the top and bottom on the front and rear that fit a Defender 110? Any ideas? IIRC they might be from a Disco. Thanks Neill Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2010 Share Posted October 20, 2010 not seen amy that'll fit a Defender 110's rear springs because the spring diameter on a 110 is larger than on a 90, Discovery ones will fit the front though. plus they'll give you a lift of 25mm IIRC. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 20, 2010 Author Share Posted October 20, 2010 Any idea on part # ? I could have sworn Mike said something about the rears....Is it only the 110 and 130 with 7 inch. Are the Disco rears 6inch ? BTW Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2010 Share Posted October 20, 2010 ANR3060 ANR2938 don't know of any for that will fit 110/130 rear springs. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted October 20, 2010 Share Posted October 20, 2010 Have a look at these - Old Man Emu 10mm Trim Packer (OME80PR10) The Old Man Emu 10mm Trim Packer is designed to act as a shim to level out listing Defender 110. Fit an OME80PR10 Trim Packer to to the top of the rear spring on your Defender 110's low side to level things out if your vehicle lists to one side. . Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 20, 2010 Author Share Posted October 20, 2010 Thanks both. Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted October 20, 2010 Author Share Posted October 20, 2010 Will these fit for the front? RBC100111 Use those on the top and then ANR2938 on the bottom? Quote Link to comment Share on other sites More sharing options...
western Posted October 20, 2010 Share Posted October 20, 2010 RBC100111 are the later version, so will fit, IIRC these only fit on top of the springs. Quote Link to comment Share on other sites More sharing options...
