LR90 Posted June 13, 2006 Share Posted June 13, 2006 I was considering putting longer shocks on the 90 and letting the rear springs dislocate or stretch a bit more but have noticed that even with the current +3" shocks the front uj of the prop is binding when the axle is hanging on the shocks (this is with stock shock mounts). So, all you guys and gals running +2s or longer with lowered shock mounts how have you solved this? Quote Link to comment Share on other sites More sharing options...
ripley Posted June 13, 2006 Share Posted June 13, 2006 I was considering putting longer shocks on the 90 and letting the rear springs dislocate or stretch a bit more but have noticed that even with the current +3" shocks the front uj of the prop is binding when the axle is hanging on the shocks (this is with stock shock mounts).So, all you guys and gals running +2s or longer with lowered shock mounts how have you solved this? ive got extended sliders & wider angled props on the defender, i know people that have made spacers instead Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 13, 2006 Author Share Posted June 13, 2006 Hmm, cheers Graham nice to see someone has seen and addressed the problem. Don't think I have an issue with length yet but my setup is pretty tame. Did you consider a centre check strap? Quote Link to comment Share on other sites More sharing options...
ripley Posted June 14, 2006 Share Posted June 14, 2006 Hmm, cheers Graham nice to see someone has seen and addressed the problem. Don't think I have an issue with length yet but my setup is pretty tame.Did you consider a centre check strap? No, when I went 3Link, I wanted as much movement as poss, so decieded on travel length & then worked backwards from there, I wouldnt go with as much movement again, ive found that i have too much drop front & rear, which doesnt help in certain situations ie Side slopes Quote Link to comment Share on other sites More sharing options...
LR90 Posted June 14, 2006 Author Share Posted June 14, 2006 For now I'll live with it, got other things to spend the pennies on. Still toying with cutting the tub about as I'm not using all the available up movement yet but the procomps are coming up for replacment and it might have been nice to go for something longer, maybe with some of Gwyns mounts. Quote Link to comment Share on other sites More sharing options...
ELVIS Posted June 15, 2006 Share Posted June 15, 2006 I was considering putting longer shocks on the 90 and letting the rear springs dislocate or stretch a bit more but have noticed that even with the current +3" shocks the front uj of the prop is binding when the axle is hanging on the shocks (this is with stock shock mounts).So, all you guys and gals running +2s or longer with lowered shock mounts how have you solved this? went out with a few mates on sunday. one had a brand new double cardin rear prop from a well known off road parts supplier. he did 15 or so miles on it , drove into the first mud of the day (6") on a hard rock base, and........................ BANG , it let go big style. on examining it , it APPEARS to be cast and not forged! fit for SCRAPIRON!!!!! Quote Link to comment Share on other sites More sharing options...
JST Posted June 17, 2006 Share Posted June 17, 2006 not currently running wide angle props but certainly looking into the possibility - see my note of UJ wear in Int Forum Quote Link to comment Share on other sites More sharing options...
Porny Posted June 17, 2006 Share Posted June 17, 2006 Kenson do a nice range of high angle props (complete with longer sliders).... Tel: 0121 505 3668 Haven't got one, but have always been impressed with other their other products.... and they are not orange! Ian Quote Link to comment Share on other sites More sharing options...
mwncidur Posted June 17, 2006 Share Posted June 17, 2006 wide angle props were fitted as standard on the rear of range rovers up to 1976ish. just cut and shut yourself. its easy, i've done loads. Quote Link to comment Share on other sites More sharing options...
