des90 Posted November 8, 2010 Share Posted November 8, 2010 Hi all- I'v got the 90 going brilliantly on the megasquirt but keep having a problem with the fuel relay failing.It runs the fuel pump and lambda.Have tested all the wiring-all ok-and tried different relays-even shelling out for a range rover one.All to no avail-Anybody got any ideas?? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 8, 2010 Share Posted November 8, 2010 Hi all- I'v got the 90 going brilliantly on the megasquirt but keep having a problem with the fuel relay failing.It runs the fuel pump and lambda.Have tested all the wiring-all ok-and tried different relays-even shelling out for a range rover one.All to no avail-Anybody got any ideas?? Possibly I had this trouble on a racer engine I worked on, even a "New" relay didn't sort it. In desperation I took an Old BOSCH Metal silver coloured old one - and sorted. Not all relays are worth using I found The ones on the old Hotwire and Flapper looms are very good quality also check the cleanyness and fit of the connectors within the relays Nige Quote Link to comment Share on other sites More sharing options...
des90 Posted November 8, 2010 Author Share Posted November 8, 2010 Possibly I had this trouble on a racer engine I worked on, even a "New" relay didn't sort it. In desperation I took an Old BOSCH Metal silver coloured old one - and sorted. Not all relays are worth using I found The ones on the old Hotwire and Flapper looms are very good quality also check the cleanyness and fit of the connectors within the relays Nige Hi Nige- yeap tried old and new range rover ones.I was wondering if it was something to do woth driving a motor ie the injection pump. I have been using 30amp units-wonder if 40amp would make any difference?? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2010 Share Posted November 8, 2010 I never bother buying 30A ones, as Nige says not all relays are created equal. Then again, I had a dodgy fuel pump on my RRC which never blew fuses but killed relays, go figure. Quote Link to comment Share on other sites More sharing options...
des90 Posted November 8, 2010 Author Share Posted November 8, 2010 I never bother buying 30A ones, as Nige says not all relays are created equal. Then again, I had a dodgy fuel pump on my RRC which never blew fuses but killed relays, go figure. Yes I'm thinking along those lines-looks like a new inline pump is the next step! Quote Link to comment Share on other sites More sharing options...
