ady 1 Posted November 17, 2010 Share Posted November 17, 2010 hi there. does anybody know how to check to see if centre diff is working properly.diff light not wired up.but i need to check to see if it is working correctly first.if its not doing what its supposed to how difficult is it to fix. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 17, 2010 Share Posted November 17, 2010 Put a jack under one axle, lift one wheel off the ground. Diff lock out = wheel spinning Diff lock in = truck tries to drive off the jack. Check the wires on the top of the switch (front/top face of the box) they can get broken quite easily. Quote Link to comment Share on other sites More sharing options...
pete300tdi90 Posted November 17, 2010 Share Posted November 17, 2010 when he says tries... it will, so mind them toes! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 18, 2010 Share Posted November 18, 2010 Or a safer option: Diff lock out = wheel spins by hand Diff lock in = wheel doesn't spin by hand The LT230 is not a complex beastie to have apart, this thread shows everything you need. The only if it's not working is if there's actual damage inside - broken bits of metal whirling round is generally bad news for gears & shafts & bearings, and that would make it a bigger job. If it's really damaged inside, a good 2nd hand unit shouldn't be more than £200, more like £100. Quote Link to comment Share on other sites More sharing options...
