JJB Serenity Posted December 13, 2010 Share Posted December 13, 2010 (edited) Hi all, does anyone know the part no for the heavy duty valeo clutch for the 200Tdi Defender? Is it even available for the 200Tdi? Many thanks John Edited December 13, 2010 by western title amended cos you screwed it up Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2010 Share Posted December 13, 2010 Friction plate was FTC1994 now UQB000130 Pressure cover URB100760 Release bering for LT77 is FTC5200 or if main gearbox is stumpy bell housing R380 use UTJ100210 crankshaft rear spigot bush LFB500050 hth Quote Link to comment Share on other sites More sharing options...
JJB Serenity Posted December 13, 2010 Author Share Posted December 13, 2010 Friction plate was FTC1994 now UQB000130 hth I thought it might be FTC1994 but wasn't sure because when I looked at the link you gave me before it gave that part number for "clutch plate (Diesel 130)" and I wasn't really sure what that meant. Many thanks Western, sorry for being so mechanically inept! Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2010 Share Posted December 13, 2010 FTC1994/UQB000130 has 8 damper springs the previous standard plate had 6 IIRC. Quote Link to comment Share on other sites More sharing options...
ratmanrover Posted April 8, 2012 Share Posted April 8, 2012 sorry this is an old topic but this plate FTC1994/UQB000130 will it go into a 300tdi 90? As just found that its a HD item and tow a lot of heavy trailers, will i also need a different pressure plate? Dave Quote Link to comment Share on other sites More sharing options...
western Posted April 8, 2012 Share Posted April 8, 2012 It will fit any Tdi engined Land Rover not just Defenders or 90/110/130 pressure plate is common as listed in my original reply above Quote Link to comment Share on other sites More sharing options...
muddy Posted April 8, 2012 Share Posted April 8, 2012 I did alot of research int HD clutches, the '130' one has maginaly more area on the plate but has the same clamping force as standard. AFAIK there are only two truly HD plate clutches, a britpart one and an ap racing one. Rakeway engineering will supply either. I have had a britpart one in my 90 since november and covered approx 5000miles of pretty hard driving and its still fine (franticaly stroking and caressing wood ) Infact i have been so impressed i fitted one to my dads hicap when he ripped the centre out of his old one. Will. Quote Link to comment Share on other sites More sharing options...
