bushwhacker Posted January 2, 2011 Share Posted January 2, 2011 Hello. I've had a wee trawl and beleive my head gasket has blown on my 200tdi. Could someone confirm this from blue smoke from the oil filler with chuffing, oil down the sides of the block and the water pressurizing at the expansion tank. 220,000 on the clock. I have cleaned the breather pipes and they were not blocked. It's still starting ok. Any helpful thoughts would be appreciated very much. Thanks Quote Link to comment Share on other sites More sharing options...
bear Posted January 2, 2011 Share Posted January 2, 2011 Hi Bushwacker, Sounds very much like it to me. Had a similar thing on my 200 tdi when the fumes were coming out of the dip stick hole. Known fault on the original head gaskets and they are now replaced with ones with thicker walls. Used to go about 60 to 80,000 so you've done well if it's the original. Regards Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 2, 2011 Share Posted January 2, 2011 Sound like haed gasket to me! Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 2, 2011 Author Share Posted January 2, 2011 Thanks for the info guys. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 3, 2011 Author Share Posted January 3, 2011 Can anyone suggest the best people or make for head gasket, valve stem oil seals, rocker gasket and any thing else to do a fix on this. Would it be a good idea to stick new valves in, I am in NI so the head will be done local when I find out who are best. Thanks Quote Link to comment Share on other sites More sharing options...
fozsug Posted January 3, 2011 Share Posted January 3, 2011 Can anyone suggest the best people or make for head gasket, valve stem oil seals, rocker gasket and any thing else to do a fix on this. Would it be a good idea to stick new valves in, I am in NI so the head will be done local when I find out who are best. Thanks Wouldnt bother with valves unless they look burnt out.Just make sure that you get the head pressure tested and skimed if necessary, and get the right thickness head gasket. As for parts i allways use genuine , i use LR Series http://www.lrseries.com/ Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 4, 2011 Share Posted January 4, 2011 The OEM head gasket is not LR, it is actually made by Elring. Bearmach and all the others sell this make of gasket. I have never used any other make. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 5, 2011 Author Share Posted January 5, 2011 Elring is the one I will go for. Thanks Quote Link to comment Share on other sites More sharing options...
Typsey Posted January 10, 2011 Share Posted January 10, 2011 How much smoke are we talking about here? I get a little bit, not much mind, but a bit of smoke from both the oil filler cap and the dipstick housing. Should I be worried about this? Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted January 10, 2011 Share Posted January 10, 2011 You can buy top end gasket re-build sets, I believe paddocks and britcar sell these (and probably lrseries will too). It should include all the gaskets to to the head Perhaps just re-grind the valves if they don't look bad, you will have to grind in new ones too. Quote Link to comment Share on other sites More sharing options...
bushwhacker Posted January 10, 2011 Author Share Posted January 10, 2011 Hi. I would say mine was excessive, oil down the sides of the block and dripping to the ground. I only intend driving it to the fornt of my garage until it is sorted. About 20 feet in all. The absence of heat in the car makes me think head gasket. Quote Link to comment Share on other sites More sharing options...
