rod baker Posted January 7, 2011 Share Posted January 7, 2011 hi guys n gals my 1983 range rover wont lock it transfercase . yes i have searched for answers in this and other forums but cant seem to find the answer i need. now here is the problem shifter works fine a little stiff from hi to low but clicks left to right easily so when i put it in either low or high lock i doesnt actually lock as it is an off road buggy and has easy access to the box i can see all linkages moveing well so any help would be good rod lt77 5speed lt230 transfer 3.5 v8 Quote Link to comment Share on other sites More sharing options...
teslo Posted January 7, 2011 Share Posted January 7, 2011 is it working when you disconnect linkage -> alignment? if still not, you will have to look inside. Quote Link to comment Share on other sites More sharing options...
rod baker Posted January 7, 2011 Author Share Posted January 7, 2011 is it working when you disconnect linkage -> alignment? if still not, you will have to look inside. i am not sure of what you are asking i do not know what to try and align it with i have used a spanner on the lock linkage to push it a little futher to the extent of free play which is is only about 1mm but this made no difference . is it possible to do a partial dissasebly on transfer to see the mechanism or is it a complete removal thanks rod Quote Link to comment Share on other sites More sharing options...
teslo Posted January 12, 2011 Share Posted January 12, 2011 try to disconnect linkage from transfer case. Then turn with mechanism in transfer case with spanner. Do you have indication that central lock is engaged? Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 12, 2011 Share Posted January 12, 2011 I wouldn't rely on any lights to tell you if the centre diff has locked - check the output flanges. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 12, 2011 Share Posted January 12, 2011 Ditto, a recent broken wire was a nice find under my truck recently Quote Link to comment Share on other sites More sharing options...
