TobyMellin Posted January 20, 2011 Share Posted January 20, 2011 Has anybody used one of these? From the description on tinley tech, it suggests that it replaces the power valve and supplies gas by monitoring manifold air pressure. Link: http://www.tinleytech.co.uk/cgi-bin/ca000001.pl I realise it may not be as good as a lambda controlled closed loop, but I've been running open loop for a month or so, due to lambda sensors not liking wading... Thanks. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2011 Share Posted January 20, 2011 Hmmm, only heard bad reports on these TBH, make very little difference, and struggle to keep up with a V8 on full chat, the VIP100 I had, and have now fitted to 2 subsequent vehicles is very good indeed, and simple to setup/fit As for lambda sensors not liking wading.... I wade, mud and water, and have had the same sensor in for about 18 months now, still works fine. Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted January 20, 2011 Author Share Posted January 20, 2011 Thanks very much for the reply. Are you getting decent economy? You couldn't get me that part number for your lambda could you? Definitely considering getting a vip100 if they're as good as you say! Cheers. Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted January 20, 2011 Author Share Posted January 20, 2011 Also, do you use the remote display for the vip100? Any idea if it's reasonably accurate? I'd be mounting the control unit etc inside the car so I may not need the remote display. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2011 Share Posted January 20, 2011 I didn't use the remote display, no, the flashing LEDs were plently, I had mine in the passenger footwell , just dangling by the wires so I could monitor whilst driving, but tuck it out of site when I was carrying a passenger, eventually it stayed hidden. Using the VIP100 I found a 10% improvement in MPG, better running through the rev range, especially high up, and generally a smoother V8, I don't run LPG on my V8 any more, due to needing the space, and not doing the mileage I was, but as I say, it has moved to two other vehicles and on both it has made a dramatic improvement, on a V8 90 it took it from 8MPG to 11.5, though I did MegaJolt it at the same time with table switching I reckon my VIP100 paid for itself within 2 months, I ran it for 12 months then gave it to a mate, as I went Megasquirt and wanted my boot back The lambda sensor I was referring to was the one I run for Megasquirt, but the LPG one took plenty of wading too, and that is on it's third truck now! It was supplied with the VIP100, so dont remember what make it is, the one I use currently is a Bosch one, I think I grabbed it from ebay when someone had a job lot of VW ones going for £25 or so, since then I have used Fuelparts sensors also with no issue, on other trucks. Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted January 20, 2011 Author Share Posted January 20, 2011 Thanks again for the info. I've got a full megajolt kit that I'll get round to fitting some time! Annoying thing is, I've bought a new lambda sensor (£50) for the current system, that didn't solve it, now I've bought the pc cables and connectors for it (£35). I'm borrowing a mates old laptop tomorrow to plug it in. If it doesn't find out what the problem is, think I'll be going for the vip100. What mpg do you get with your megasquirt by the way? I'm getting 7mpg with my open loop gas at the moment... Not sure what I get on petrol (3.9 non serp efi). Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20, 2011 Share Posted January 20, 2011 7 is terrible.... I used to get 13 on gas all the time! Megasquirt... well I don't really ever drive it unless I am spending most off the day off road, but it works out about 10 I suppose... I managed over 15MPG pulling a trailer at ~ 1 ton and loaded up with camping stuff in the summer though! Quote Link to comment Share on other sites More sharing options...
Escape Posted January 24, 2011 Share Posted January 24, 2011 I can't open the link in your post, but do have experience with the Ecomax vacuum economiser from My link. It does a good job, both on a RRC with 3.5 and a GEMS 4.0. In fact, the 4.0 with Ecomax has no problem matching our 4.6 equiped with an electronic closed loop system. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 24, 2011 Share Posted January 24, 2011 Aha, this is a different model, by the looks of things, it was this one from Tinley that I have seen reviews and opinions of: http://www.tinleytech.co.uk/kit-extras.html Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted January 24, 2011 Share Posted January 24, 2011 Chris Perfect used to sell them with their LPG kits and reconned they were better than closed-looop single point systems because they weren't effected by calorific value or something. Pretty sure theri webiste went years ago though. Quote Link to comment Share on other sites More sharing options...
TobyMellin Posted January 26, 2011 Author Share Posted January 26, 2011 I've decided to not run a lambda control system anymore. I will either run an open loop system, tuned by wideband in the y-piece (remove before off roading). or, I may try out the eco-vac. I'll ring tinley tomorrow to ask them how it works and what they think of them. new link (3rd product down): http://www.tinleytech.co.uk/acatalog/System_Upgrades.html Quote Link to comment Share on other sites More sharing options...
