old & wrinkly Posted January 25, 2011 Share Posted January 25, 2011 The other half,s td5 needs a new thermo as its running very cold (just off the blue and the heaters freezing) even after 20/30 miles !!!im fed up with being moaned at so i gotta fix it before she comes back ! Where do i start ! Quote Link to comment Share on other sites More sharing options...
PGM316 Posted January 25, 2011 Share Posted January 25, 2011 According to the haynes manual its a fairly easy job to do, well, in the 300tdi that is. Quote Link to comment Share on other sites More sharing options...
ashtray Posted January 25, 2011 Share Posted January 25, 2011 its on the bottom hose, and its inside a white ( i think) tube, has about 3 pipes coming off, should be fairly obviously, bottom right if you looking at the front of the vehicle Quote Link to comment Share on other sites More sharing options...
western Posted January 25, 2011 Share Posted January 25, 2011 Looks like this Td5 stat & photo below. Quote Link to comment Share on other sites More sharing options...
old & wrinkly Posted January 25, 2011 Author Share Posted January 25, 2011 Thanks guys. is there anything i have to be careful of when i refill the system like airlocks ect . Quote Link to comment Share on other sites More sharing options...
ashtray Posted January 25, 2011 Share Posted January 25, 2011 Fill the system with your coolant mix with the heater set to hot, run the engine, and loosen the screw on the top hose, but not all the way, just enough to let the air out, when no more air is coming from the bleed screw the system is bled, your heater should be kicking out heat by now, sometimes air locks can be quite difficult to bleed but just keep releasing that bleed screw until all is good Quote Link to comment Share on other sites More sharing options...
dantd5 Posted January 26, 2011 Share Posted January 26, 2011 Kindly don¨t draint the coolant on the lawn or driveway . Save the worms and the other organisms around. Quote Link to comment Share on other sites More sharing options...
old & wrinkly Posted January 28, 2011 Author Share Posted January 28, 2011 fitted new thermostat today. bled the system and 10 miles down the road its still the same ! just off the blue and no heat ??? im now thinking about getting rid of the mini helicopter on the front and fitting a kenlowe electric fan.. any ideas ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 28, 2011 Share Posted January 28, 2011 Removing the viscous will make precious little difference to the warm up, fix the problem, not the symptom! Open the bonnet when 'hot' do the engine/hoses feel up to temperature? If so then you could have a blocked heater/airlock. If not then you could have a blocked heater/airlock and a dicky temp sender. Quote Link to comment Share on other sites More sharing options...
old & wrinkly Posted January 28, 2011 Author Share Posted January 28, 2011 thanks. now your got me thinking ? Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted January 29, 2011 Share Posted January 29, 2011 Temp sender Water pump Check both. Feel the hoses after 30min. Both upper n lower. They should be a lil hot to the touch. If you can keep your hand on it, means the coolant is not moving. Quote Link to comment Share on other sites More sharing options...
