stuck Posted January 30, 2011 Share Posted January 30, 2011 As the title really, My TD5 van back has always wallowed like a pig in the corners but doesn't have a ARB fitted. Have ordered an X-Flex jobbie so that should improve it's on road manners but I'm curious if mine would have had one fitted originally? Thanks, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2011 Share Posted January 30, 2011 Depends on actual model spec, my '89 County 110 has a rear anti-roll bar, hardtops/pick-ups only if ordered when new, XS station wagon should have one fitted or maybe both front & rear. Quote Link to comment Share on other sites More sharing options...
stuck Posted January 30, 2011 Author Share Posted January 30, 2011 Ah, so it was an optional extra "Does Sir want his truck to be able to cope with roundabouts?" Thanks Ralph. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 30, 2011 Share Posted January 30, 2011 My 1989 Hardtop (Van) doesn't have one fitted. My understanding is that they were only fitted to vehicles with 2950kg GVW Levelled Suspension (most Station Wagons) and not fitted to vehicles with 3050kg GVW Unlevelled Suspension (Hardtops, Truck Cabs, HCPU) . Quote Link to comment Share on other sites More sharing options...
Guest Posted January 30, 2011 Share Posted January 30, 2011 I think when it comes to ARB's and defenders there is actually no rule, mine should have had them, (spec etc) but they were never fitted, I guess it is in the hands of the gods and what LR had at the time Quote Link to comment Share on other sites More sharing options...
farmerboy_y2k Posted February 1, 2011 Share Posted February 1, 2011 If your springs are in good condition there shouldn't be that much roll on a 110 hardtop, without anti rol bars. Quote Link to comment Share on other sites More sharing options...
Prith Posted February 1, 2011 Share Posted February 1, 2011 Is it necessary to have a rear anti roll bar? Mine does not have any, including the front too. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2011 Share Posted February 1, 2011 If your springs are in good condition there shouldn't be that much roll on a 110 hardtop, without anti rol bars. My springs were new and there was plenty of roll when it was loaded with all of my kit, it was surprising the difference the ARB's made especially when doing simple things like changing lanes at speed (ish) my rear ARB bushes now need changing after just a year so I guess they are under stress a lot and doing their job. Jason. Quote Link to comment Share on other sites More sharing options...
Guest Posted February 1, 2011 Share Posted February 1, 2011 Is it necessary to have a rear anti roll bar? Mine does not have any, including the front too. They are not "necessary" and it depends what you use your truck for, if you use it for lots of off roading then ARB's can affect articulation (hence Simon's great new product over at E-Eng x-deflex) which solves that problem, however if you don't use your truck for extreme off roading a standard ARB setup will give your truck more manners in high speed corners and prevent as much body roll. Jason. Quote Link to comment Share on other sites More sharing options...
Prith Posted February 1, 2011 Share Posted February 1, 2011 THanks Jason, Mostly on road and over the weekends some mild offroading. Quote Link to comment Share on other sites More sharing options...
