Stupid question about speed cable
I know this is a silly question but my hands are getting very sore trying to get the speedo cable out of the speedometer. Haynes just says "disconnect the speedometer cable" - YES BUT HOW?
It must be easy, but I can't see how.
I had the same problem until I got annoyed and levered it off with a screwdriver :unsure:
Then you see it's only held in by the plastic collar at the end of the cable which clips over the ridge on the speedo head.
If you can pull hard enough - yeh where it is makes that difficult, it does just come off.
Malcolm
Sorry, a bit slow on the uptake. Finally understood what you mean. The collar closest to the speedo needs to be squeezed. There are two pieces further away from the speedo which look like they should be squeezed :-) but they don't do anything. Finally got the cable off. Thanks for the help Western.
