tomaco1 Posted February 5, 2011 Share Posted February 5, 2011 I found this picture in a very thorough 110 build. I assume this is the G-valve found on a 110, and my question is does this work when a 110 is swapped to disc brakes in the rear? I also was wondering where to get one? and Is this the only valve used in a 110? (No PDWA or Combination Valve?) The picture is from a NAS 110 here in the states. I got the same stainless brake lines used in a NAS 110 so I'm trying to copy the setup on my 110 build Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2011 Share Posted February 5, 2011 fitted to prevent the rear brakes from locking before the front brakes, normally only fitted to commercial 110 hardtop with extra seats in the rear, not normally fitted to station wagons which use the PDWA valve instead. G valve NRC4215 PDWA unit NRC4880 Quote Link to comment Share on other sites More sharing options...
tomaco1 Posted February 5, 2011 Author Share Posted February 5, 2011 Thanks, It seems they were fitted to the 1993 110's in the states also Quote Link to comment Share on other sites More sharing options...
Tibout Posted February 6, 2011 Share Posted February 6, 2011 you'll find one on lrseries.com they are quite expensive. it was fitted to my 90 pick-up. mine was faulty and the back wheels lock so badly when braking hard it's around 108£ thierry Quote Link to comment Share on other sites More sharing options...
