bear Posted February 19, 2011 Share Posted February 19, 2011 Hi Everyone, I’ve seen several post on bleeding the brakes/clutch and do not want to start another, however, I have never had a problem using the Gunson Eezebleed. As I’m sure most of you know, fresh brake fluid is forced at 20psi through the system as long as the bleed screw is open. I used it for many years on my old 200tdi but have now “upgraded” to a D2 TD5 which has a different master cylinder cap that does not allow the use of the normal screw type caps. Gunson sell an adaptor for the new type of reservoir and I was wondering if anyone has used it and if it works ok. Regards Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted February 19, 2011 Share Posted February 19, 2011 Should be fine,I dont use more than 10-12psi when pressure bleeding,some of the resrvoirs look a bit fragile to me. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 19, 2011 Share Posted February 19, 2011 its supposed to be about 10-12psi IIRC, not 20!! Quote Link to comment Share on other sites More sharing options...
bear Posted February 20, 2011 Author Share Posted February 20, 2011 Hi folks You had me worried there so I’ve re-checked the original instructions and it does say “..no more than 20psi” and that it can be used as low as 10psi. I have had it for a long time so they may have amended the instructions recently so I’ll lower the pressure in future. Cheers for the info. Quote Link to comment Share on other sites More sharing options...
