markyb Posted February 21, 2011 Share Posted February 21, 2011 My rear +2 shocks have seen better days so need to replace. I am also running -2 drop brackets. Ive bought the terrafirma +5 shock mounts the relocation ones. ( im running +2 Oldman emu springs - dislocation cones etc) My question is. ive read a bit about double carbon props etc. I was going to try it out and limit the centre axle drop if required but thought i would ask on here. also how are people rating the terrafirm shocks should mention its a 90 truck cab , 35 simexs. will be dippping in and out of challenges as done the last 2 years of the howling. Quote Link to comment Share on other sites More sharing options...
markyb Posted February 21, 2011 Author Share Posted February 21, 2011 this is the rear only as happy with the front setup Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted February 21, 2011 Share Posted February 21, 2011 Me! I have +5" Terrafirmers with X Eng springs and arms. Running a Gwyn Lewis rear prop and have no troubles. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 21, 2011 Share Posted February 21, 2011 You should have no reason to limit the axle articulation even with standard props. Quote Link to comment Share on other sites More sharing options...
markyb Posted February 21, 2011 Author Share Posted February 21, 2011 cool. will try it out and see, thanks alot Quote Link to comment Share on other sites More sharing options...
zim Posted February 21, 2011 Share Posted February 21, 2011 Use a set of Gwyns shock mounts instead of your -2's. G Quote Link to comment Share on other sites More sharing options...
the bey Posted February 21, 2011 Share Posted February 21, 2011 I ran +5 on rear with no probs with a 2 inch lift. only thing to watch is they can bottom before anything else if running -2 mounts, worth checking. You don't want to bend one. ;-) Quote Link to comment Share on other sites More sharing options...
pooler70 Posted February 21, 2011 Share Posted February 21, 2011 I am running terrafirma +5 on a 2" lift and standard prop. Havent had any problems so far. Using the terrafirma brackets with the +5. I have set my bumpstop to limit movement before it bottoms out on the shock! Quote Link to comment Share on other sites More sharing options...
markyb Posted February 21, 2011 Author Share Posted February 21, 2011 cool. i have the terrafirma mounts to go with it so should be ok, bit like the Gwyn lewis mounts I have plus 2 bump stops so will see what its like on compression, Quote Link to comment Share on other sites More sharing options...
lansalot Posted February 21, 2011 Share Posted February 21, 2011 Get some dislocation cones with hooks at the bottom - your springs might settle outside the cone if not and press against the tyre. Which isn't good.. Quote Link to comment Share on other sites More sharing options...
pooler70 Posted February 23, 2011 Share Posted February 23, 2011 Get some dislocation cones with hooks at the bottom - your springs might settle outside the cone if not and press against the tyre. Which isn't good.. This is good advice. I found my springs will drop out my current dislocation cones on full articulation. Worth swopping before you get problems. Quote Link to comment Share on other sites More sharing options...
