bow Posted April 18, 2011 Share Posted April 18, 2011 having trouble finding a cir-clip for the brake on my standard 8274, no one seems to stock them, been to all the useual, devon, gigglepin and so on, i only want a sodding cir-clip, warn will only supply as part of a kit at £75, can any one measure one and give me the figures, then i'll go source a load, finding this is a common problem, so if i can get them i will, and put them out at cost plus postage thanks all, Bow.. Quote Link to comment Share on other sites More sharing options...
Dave W Posted April 18, 2011 Share Posted April 18, 2011 The ID is 24.3 mm and it's 2mm thick, OD is 30mm - or at least that's what the one I have in my spares box measures. They are probably not required that often these days as the GP upgrade negates the need for them. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 18, 2011 Share Posted April 18, 2011 one of these might fit, Bow. I,ve used this company before. http://www.ondrives.com/mechanical-circlips-to-suit-4-50mm-shafts.html Quote Link to comment Share on other sites More sharing options...
bow Posted April 18, 2011 Author Share Posted April 18, 2011 thanks Dave, I'll be looking at the gigglepin upgrade next, but money is limited, so will do one part at a time, thanks again for the dimensions.. Quote Link to comment Share on other sites More sharing options...
bow Posted April 18, 2011 Author Share Posted April 18, 2011 thanks for the link Mark, finally got myself an 8274, just need to get it up and running, see you at Manby if not before... Quote Link to comment Share on other sites More sharing options...
gsr341 Posted April 18, 2011 Share Posted April 18, 2011 bow may have a spare , will have a look if i can find it its yours mate dafydd Quote Link to comment Share on other sites More sharing options...
D3DPE Posted April 18, 2011 Share Posted April 18, 2011 remember it is not a standard circlip. One side is flat and one in dished! If all else fails bow I will have one kicking about some where or in stock! But if your winch hasn't got one on maybe it has let go at some point, if this is happened some times they just dont like staying on any more, so maybe add a spec of weld when you fit the clip. D Quote Link to comment Share on other sites More sharing options...
bow Posted April 18, 2011 Author Share Posted April 18, 2011 well after a busy night stripping the winch a bit further i've fond a few more problems with it, the small neadle bearing on the end of the mainshaft is shot, guess at some stage this had an external cap that is long gone, will call gigglepin again in the morning to see if its available, think i might spend a bit of time on the lathe and turn up a retaining cap simular to gigglepins to hold the brake on, cant afford an upgrade yet, thanks Dafydd and Dan, think i may as well do it right while i have it appart, its main purpose will be recovery not competeing so cant see it being over worked, only wanted an 8274 cause i'm a tart, will put my 9.5si on for now until i can get it finished propperly, might take some pics for the forum as i do bits, plenty on pirate, but not on here, thanks all, looks like its time to spend some money .. Thanks all.. Bow.. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted April 19, 2011 Share Posted April 19, 2011 can remember the size of the needle roller bearing , but it is readly availble from most bearing supplyers as are the two in the top housing Quote Link to comment Share on other sites More sharing options...
Tractorboy16 Posted April 20, 2011 Share Posted April 20, 2011 Um, if you search the part number on the internet and then put that into the Devon4x4 search bar you shall find it, try searching 'warn circlip' in there search I know this for sure as they delivered 2 to me Yesterday. Or, it is amazing what the power of words are. Just pick up the phone and ring them and they would be able to put some in the post the next day for you. This is the circlip on devon. http://www.devon4x4.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=11672&category_id=-2&keyword=warn+circlip&option=com_virtuemart&Itemid=14 James Quote Link to comment Share on other sites More sharing options...
bow Posted April 20, 2011 Author Share Posted April 20, 2011 thanks James, i never knew that section existed, looked on the site under warn section, phone call was going to be last resort, winch is totally stripped now, just waiting on my parts then I'll re-build it, thanks, Quote Link to comment Share on other sites More sharing options...
