Nobbymogs Posted May 2, 2011 Share Posted May 2, 2011 has any one stripped a TDS mines needs a good service me thinks its slipping now and again like the brake isnt working or isnt engaged but sometimes it works very strange i know but it needs to be sorted i also read somewhere that if you remove all the silly grease that they build it with and use something a bit thinner it makes it work even better any ideas and tips would be great thanks Nobby Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 2, 2011 Share Posted May 2, 2011 Ive stripped mine down and removed all the original grease and carp that had got in, replaced the grease with One shot CV grease. Its pritty simple inside Dave. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 3, 2011 Share Posted May 3, 2011 Dave - How much of the one shot grease pack did you put in? I personally haven't stripped a TDS, but I guess it's like an EP9, which I have stripped and that was faily simple to take apart. I put sealent on all the mating surfaces when it went back together. There's some tech on the EP9 in the tech archive here. Steve Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted May 3, 2011 Share Posted May 3, 2011 Dave - How much of the one shot grease pack did you put in? I personally haven't stripped a TDS, but I guess it's like an EP9, which I have stripped and that was faily simple to take apart. I put sealent on all the mating surfaces when it went back together. There's some tech on the EP9 in the tech archive here. Steve Steve properly not enough is the answer! The old stuff was really thick and was everywhere but the CV grease is very thin in comparison... About a 1/3rd of the bottle that it comes in (britpart as its a bottle rather than a squeezy tube) I have also done what Steve mentioned and used sealant to seal the mating surfaces. Dave. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 3, 2011 Share Posted May 3, 2011 I guess that would make sense as I put in just over half of a one shot grease sachet. The motor end is a bit coroded and dirty, so I've stripped it and it just needs cleaning now, hopefully the other end is still all sealed and should still work fine! Steve Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 3, 2011 Share Posted May 3, 2011 Stripped mine recently, very simple inside, and the gearbox end was still very well sealed, no corrosion at all, which is not what can be said for the Bowmotor on the other end :x The brake is serviceable by just removing 3 screws IIRC, then the cone comes off and you can inspect the pads/surfaces etc, delving in further give you the gearbox two halves and three stage planetry gearbox, which can only go back in one way, so no problem at all really. Silicon afterwards to re-seal, and a smear of grease on the drum end plate seals before reassembly. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 3, 2011 Share Posted May 3, 2011 And as Bowie said, and to answer one of your questions Nobby, to access the brake unit you just need to remove the three cap head bolts that hold the end cover onto the gearbox. Steve Quote Link to comment Share on other sites More sharing options...
