nige90 Posted May 3, 2011 Share Posted May 3, 2011 My X reg Td5 has developed yer another fault, this time a warning chime sounds. Seems to do it after a short journey followed by a short stop, to petrol station for example. It pings once every two second for one minute then stops. No lights come on at all. Ideas ? Quote Link to comment Share on other sites More sharing options...
M&S Posted May 3, 2011 Share Posted May 3, 2011 Key in and door open. Door open and lights on. Other than that, with no dash lights on, I'm not sure, sorry. Actually, it could be the self leveling suspension if you have it? Does it chime with the key in but engine off, or when the engine is started, or when you are actually driving? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 3, 2011 Share Posted May 3, 2011 I'm pretty sure our disco 2 chimed when you left the key in the ignition but a door open. Quote Link to comment Share on other sites More sharing options...
q-rover Posted May 3, 2011 Share Posted May 3, 2011 Mine has got one as well. Three bongs on startup. No other warninglights. Totally irregular and really annoying. Quote Link to comment Share on other sites More sharing options...
M&S Posted May 3, 2011 Share Posted May 3, 2011 The three chimes is normal. I was told it is a "system ok" check (with no warning lights on that is). According to page 70 continuous chimes in Gulf States and some other areas is a seatbelt warning chime...maybe yours has somehow decided you've moved to somewhere warmer Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 3, 2011 Share Posted May 3, 2011 The three chimes is normal. I was told it is a "system ok" check (with no warning lights on that is). According to page 70 continuous chimes in Gulf States and some other areas is a seatbelt warning chime...maybe yours has somehow decided you've moved to somewhere warmer Well with all the warmer weather recently!! Quote Link to comment Share on other sites More sharing options...
nige90 Posted May 3, 2011 Author Share Posted May 3, 2011 Happens a few hundred yards after setting off, whilst in motion all doors shut. I considered the suspension but shouldn't that display the light on the dash ? Quote Link to comment Share on other sites More sharing options...
Smego Posted May 3, 2011 Share Posted May 3, 2011 Would guess seatbelt warning when driving over 20mph remove your seatbelt and see if you get any other warnings? I used to get it in my old volvo when I had a pc on the passenger seat :-) Quote Link to comment Share on other sites More sharing options...
M&S Posted May 3, 2011 Share Posted May 3, 2011 It should, and so should the seatbelt if it was that. Strange. I'd be intereste dto know the cause myself now Try disconnecting the battery for 30mins, that often sorts out the silly faults - just make sure you have your radio code handy Quote Link to comment Share on other sites More sharing options...
