max-ie Posted May 10, 2011 Share Posted May 10, 2011 Hi Chaps, just been to Driffield last weekend and had a brilliant time. Bought some new, smarter seats and some plus 2 inch Terrafirmer Shocks for the rear. On the drive home the truck developed a nasty wobble when turning right and the steering wheel seemed to be jagged and snatching when returning it to the straight position. The sensation is like a wheel badly buckled with the front of the truck wobbling from side to side. I got out and checked everything over all the wheel nuts were tight, balljoints and trackrod arms also. Its more or less standard Range rover power steering and axle with a 2 inch lift. No castor correction though but its driven fine since i built it two years ago. Can anyone relate these symtoms with a fault. I'm stumped as it all looks ok. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted May 10, 2011 Share Posted May 10, 2011 Panhard rod bushes? I had a similar sensation once (The panhard had actually fallen off. ) Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 11, 2011 Share Posted May 11, 2011 A dying CV will interfere with the steering and might cause your symptoms. Jack up the front on full right lock and spin each wheel in turn. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 11, 2011 Share Posted May 11, 2011 I would suspect a dying cv too. HTH Mo Quote Link to comment Share on other sites More sharing options...
max-ie Posted May 13, 2011 Author Share Posted May 13, 2011 I've replaced the panhard bushes today and it's cured it. Thanks to all that replied. My truck feels more direct on the steering now and is better to drive. Quote Link to comment Share on other sites More sharing options...
