Frogland Posted May 15, 2011 Share Posted May 15, 2011 What causes that small tinny, metallic click I can hear when i'm bringing the gears down from 5th to 4th ? (R380 box) Quote Link to comment Share on other sites More sharing options...
Hazza Posted May 15, 2011 Share Posted May 15, 2011 What causes that small tinny, metallic click I can hear when i'm bringing the gears down from 5th to 4th ? (R380 box) That's the gate that prevents you going from 5th to reverse! Harry Quote Link to comment Share on other sites More sharing options...
Frogland Posted May 15, 2011 Author Share Posted May 15, 2011 That's the gate that prevents you going from 5th to reverse! Harry Seriously ? Quote Link to comment Share on other sites More sharing options...
western Posted May 15, 2011 Share Posted May 15, 2011 might be the 3rd/4th bias spring reseating after it's moved, it's on top of the gearlever turret. Quote Link to comment Share on other sites More sharing options...
stuck Posted May 15, 2011 Share Posted May 15, 2011 You drive a Defender and can hear a Tinny Click?! Quote Link to comment Share on other sites More sharing options...
Hazza Posted May 15, 2011 Share Posted May 15, 2011 Seriously ? Yes seriously Mine is the same and always has been. It should make than noise even if the engine isn't running. It's a singular loud click or clack noise. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted May 16, 2011 Share Posted May 16, 2011 it's a click. you can try it out on a R380. it's the gate that stops you from thinking you have a 6th gear. to hear it, you can turn off the engine, push into gear 5 and then back to neutral. you'll hear this click. Normal. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 16, 2011 Share Posted May 16, 2011 If you DON'T get a click you could be in trouble Quote Link to comment Share on other sites More sharing options...
Frogland Posted May 17, 2011 Author Share Posted May 17, 2011 If you DON'T get a click you could be in trouble Thanks for the replies guys. Quote Link to comment Share on other sites More sharing options...
