eastw77 Posted May 22, 2011 Share Posted May 22, 2011 Hi, I went out offroading yesterdsy and the old girl was not too keen on going into low range. No problem moving the lever but there were some crunching noises when trying to engage low range and diff lock. Once into gear it kept jumping out and I had to hold the lever over for a while for it to stay in. It's a 1988 with the LT230 transfer case and a ZF4HP22 automatic box which was in neutral and the vehicle was stationary. Can anyone offer any advice on what the problem could be? Quote Link to comment Share on other sites More sharing options...
g&t Posted June 1, 2011 Share Posted June 1, 2011 Transfer lever to 'box linkage not allowing the gears to engage fully? It's not uncommon for the initial selection of low-range to produce a slight 'crunch' but I've not had one jump out of gear, though to be fair I don't off-road Classics, just select the low gears & diff-lock monthly to keep the system operational. Could this task (not being performed?) be a clue to your problem & is this the first time you've used it in anger? Sorry I can't be more helpful, hope you get it sorted. Quote Link to comment Share on other sites More sharing options...
Biffo Posted June 1, 2011 Share Posted June 1, 2011 you're much better with the vehicle moving slightly at around walking pace or less when changing from one ratio to the other, this gives the ratio change gears to align with each other and they'll slip in together. If too much force is applied to try to get it "to go into gear" when it's not lined up just right, then you will bend this piece of the linkage, then it will never go in correctly again. Note; it's a right sod to change as well!! Quote Link to comment Share on other sites More sharing options...
Pete The Biker Posted June 1, 2011 Share Posted June 1, 2011 My RRC sometimes jumps out of low range when I go off-roading, but only if the low range knob is not pushed fully forward. To avoid trouble, once I get the car moving in low range I keep pressure on the knob (oooh err missus) until I am sure that it is fully engaged. Pete Quote Link to comment Share on other sites More sharing options...
