defender dinky Posted May 26, 2011 Share Posted May 26, 2011 hi all,d90 1987 200tdi coversion, i had a droning noise on the 90, so i removed front propshaft and put in to difflock and drove about three miles noise had gone completely, would a warn flange in the diff cause this noise,or would it be the flange on the gearbox end,when parked i can rotate the gearbox flange11/4", the noise always got louder the faster i got, is there any pictures out there of a good flange, and a bad one, haven'nt put prop back on yet i want to try and solve it asap, :huh: cheer's dinky Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 26, 2011 Share Posted May 26, 2011 What condition is the propshaft in? Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 26, 2011 Author Share Posted May 26, 2011 What condition is the propshaft in? propshaft is ok no movement in the uj's Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 26, 2011 Share Posted May 26, 2011 Can you move the flange in and out at all, like forward and back in relation to the vehicle? Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 26, 2011 Author Share Posted May 26, 2011 Can you move the flange in and out at all, like forward and back in relation to the vehicle? hi, flange on gearbox no, flange on diff moves about 2mm Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 26, 2011 Share Posted May 26, 2011 Then you've got a knackered pinion bearing, and probably a knackered ring and pinion gearset too as a result Almost certainly the cause of the whine, this sort of whine tends to stop if you take your foot off the throttle, or remove the prop as you say. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 26, 2011 Author Share Posted May 26, 2011 Then you've got a knackered pinion bearing, and probably a knackered ring and pinion gearset too as a result Almost certainly the cause of the whine, this sort of whine tends to stop if you take your foot off the throttle, or remove the prop as you say. could it be shims are to thick on the tail bearings of the pinion shaft,if i tighten the castle nut, all i'm doing is pulling the pinion towards me but if the shims are to thick would they prevent the tail bearing from sitting in the races properly, but saying that the split pin is in the hole of the castle nut, just a thought, Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 26, 2011 Share Posted May 26, 2011 It will be a worn bearing then, the shims would not need changing as the diff wears. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted May 26, 2011 Author Share Posted May 26, 2011 It will be a worn bearing then, the shims would not need changing as the diff wears. ok thanks for your help, dinky Quote Link to comment Share on other sites More sharing options...
