AdeParko Posted June 1, 2011 Share Posted June 1, 2011 Has anyone ever fitted any plastic arches to there 200/300tdi? I bought somw arches from Ebay to try and tidy up the exterior apperance of mine, but the instructions are useless I received 6 arches to suit my 5 door, and a roll of rubber seal. And the instruction say that I need some adhesive thats not provided with the arches, and give a LR part code for it Only thing, is the arches are hollow, so how do you bond them on the car? And where does the rubber seal go? Any help would be greatly appreciated Thanks Ade Quote Link to comment Share on other sites More sharing options...
Stevie D Posted June 4, 2011 Share Posted June 4, 2011 Has anyone ever fitted any plastic arches to there 200/300tdi? I've taken a set off an xs I was breaking recently - they were factory installed, and seemed to have been stuck on with some sort of narrow foam double sided tape tbh. 3M make some good stuff called VHB but it's expensive, I'm sure you could get something else cheaper - looks a bit like the sticky pads for number plates. Steve Quote Link to comment Share on other sites More sharing options...
karlo Posted June 5, 2011 Share Posted June 5, 2011 Depends on what type you have? http://www.devon4x4....ow-to&Itemid=36 http://www.devon4x4....ow-to&Itemid=36 Quote Link to comment Share on other sites More sharing options...
RWelbourne Posted June 8, 2011 Share Posted June 8, 2011 mine were pretty easy to fit self tapping screws just had to cut the arches back, so it was a lie up and mark job Quote Link to comment Share on other sites More sharing options...
tel Posted June 9, 2011 Share Posted June 9, 2011 you want a product called tiger seal or sikoflex readily availible at your local factors Quote Link to comment Share on other sites More sharing options...
