markyb Posted June 24, 2011 Share Posted June 24, 2011 I have a through cab type snorkel and i had a 400bhp filter on the end or so it said, anyway its got blocked as maybe too fine for the dust and carp of, offroading . coming back from seven sisters i was struggling to get any power so i removed it and the truck was back to full power problem solved. I am after a sponge type 3 inch if possible , what are people using on and off road as offroad i didnt notice to much and i use this on the road as well. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 24, 2011 Share Posted June 24, 2011 Normal snorkel top plus the normal air filter in the engine bay? I don't see a need for extra filtration, unless you've done away with the internal filter? Quote Link to comment Share on other sites More sharing options...
markyb Posted June 24, 2011 Author Share Posted June 24, 2011 yeah, 3inch pipe via a silcon adaptor to the inlet so i can be sure its water tight i could have a box at the end etc . those sand partical tops they any good or presume you need additional Quote Link to comment Share on other sites More sharing options...
Team Idris Posted June 25, 2011 Share Posted June 25, 2011 I'm running the standard rangy V8 ones. I recon the snorkel hose itself is a bit of a filter; as the inside gets dirty, that must be dirt not reaching the filters? But your system sounds well installed, so I'd nip down to the local agri dealer and get somthing off a tractor. They are much larger in area, as they work in dust. I ran a Deutze one for a few years. The cintrifugal pre-cleaners are good, but use engine power to work properly (air intake speed is needed to get it all spinning fast, so they are matched to the working engine speed). Check out these guys http://www.agriemach.com/ . They do proper filter bodies and a lot of racing type stuff. I got my exhaust wrap from there. Well worth a smurf - I'd love to see there warehouse Quote Link to comment Share on other sites More sharing options...
markyb Posted June 25, 2011 Author Share Posted June 25, 2011 cheers mate i will check them out and get a tractor job i reckon ta Quote Link to comment Share on other sites More sharing options...
