Steve King Posted June 29, 2011 Share Posted June 29, 2011 I'm considering fitting levelling headlamps for when I'm towing or carrying heavy loads. My TD5 has a space on the centre dash for the switch. So far my research shows that I need 2 motors for the headlights plus the levelling type of headlamp bowls and the switch. I've located sellers of all the items except the switch; does anyone know of a stockist? Quote Link to comment Share on other sites More sharing options...
PaulMc Posted June 29, 2011 Share Posted June 29, 2011 I'm considering fitting levelling headlamps for when I'm towing or carrying heavy loads. My TD5 has a space on the centre dash for the switch. So far my research shows that I need 2 motors for the headlights plus the levelling type of headlamp bowls and the switch. I've located sellers of all the items except the switch; does anyone know of a stockist? AMR5874 for a 90 AMR5875 for a 110 I've no idea what the difference is, apart from the price http://www.rimmerbros.co.uk/Item--i-AMR5874 http://www.rimmerbros.co.uk/Item--i-AMR5875 The connector to suit these switches is also used as the Female half of an Earth Header on Discovery II and Freelander 1, as well as several Rover Cars, including Metro/Rover 100 and Rover 200/400 Callout #1 here - Callout #4 here - It used to be available as YPC10004, but has been discontinued as a spare. If you source a connector from a scrappy, then suitable replacement terminals can be sourced from Polevolt - http://www.polevolt.co.uk/acatalog/Terminals_for_Connector_Housings.html Ref: 30-640/10 Female terminal for circular power connector. Supplied in multiples of 10. Price per 10: £1.00 (£1.20 Including VAT at 20%) See also - http://forums.lr4x4.com/index.php?showtopic=26669&view=findpost&p=442841 . Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 29, 2011 Share Posted June 29, 2011 Vambo, I did it on mine. The wiring should already be there, I got the bowls and motors off ebay (they are expensive new !) and the dash switch from a forum member. Worked splendidly on our trip with the 90 fully loaded HTH Mo Quote Link to comment Share on other sites More sharing options...
Steve King Posted June 30, 2011 Author Share Posted June 30, 2011 Thanks guys Quote Link to comment Share on other sites More sharing options...
