dantd5 Posted July 5, 2011 Share Posted July 5, 2011 Can i find seals to repair them? I have on the other hand ordered a new one for replacement. Truck is a 99 My Defender TD5.. Quote Link to comment Share on other sites More sharing options...
western Posted July 5, 2011 Share Posted July 5, 2011 no seal kit listed in microcat parts for these pumps, I don't know if there is a seal repair kit for them. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted July 6, 2011 Author Share Posted July 6, 2011 Thanks Ralph. I just had to buy a new one. over 100 quid... Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted July 8, 2011 Share Posted July 8, 2011 I had a leak from my pump recently, and although it is listed as a non-maintainable item, I took it off and removed the HP connection, which was where the fluid was leaking from, and found that an O-ring had perished. A quick visit to a local hydraulics factor for a ten cent O-ring, and I was back on the road. Lots cheaper than a new pump! The motto - even if it's a non-maintainable unit, open it up and give it a go. You've nothing to lose. Mike Quote Link to comment Share on other sites More sharing options...
dantd5 Posted July 8, 2011 Author Share Posted July 8, 2011 Hei Mike.. Thanks for the advice. I did open it up (an attempt to save some £££ and found out that the o-ring was in good order. However, the problem was with the seals under those 4 umbraco bolts. So I will definitley get hands on some seals (cut them up meself) and refurb it. Quote Link to comment Share on other sites More sharing options...
