Shocks and springs query
chazsmash
Just a quick question, as far as my understanding(very basic knowledge)goes, would i be right in presuming a set of 2 inch lifted springs would be compatible with a standard height set of shocks?? The vehicle is an 89 3.5efi vogue se i am refurbing. many thanks for any help.
Cheers Charlie
Are you planning to off road it? Standard shocks will do but if your offroading it you might find you'll "cock a leg" as the shocks won't travel too far.
Mines still runs front shocks as standard but rear ones are +2"....". Easy to fit and not too expensive, well worth while
Some manufacturers do 'offroad' (soft) spec and 'heavy duty' (hard) spec. Heavy duty springs are stiffer and can flex less but the offroad ones can be really soft as well as longer so longer shocks would take advantage of that. All comes down to the weight of the truck and what you want to do i guess. Mine has offroad springs and with 5 people and some stuff in the boot the tyres will rub the rear arches on a bumpy road :unsure:
