Phil B Posted July 14, 2011 Share Posted July 14, 2011 My 94 es d1 300tdi speakers are shocking (well the rear ones are) the front ones have been replaced but I'll want to replace them with all the same What size are the fronts n rear pillars??? What are direct fit, i have a broad spectrum of music from led zeplin to euphoria aswell as playing movies for me and my little lad Also my rear sub speakers in the door don't work (not that this makes a difference but is there a hidden amp or speaker wires?? My only other option is a little amp hidden in the rear door Quote Link to comment Share on other sites More sharing options...
tel Posted July 14, 2011 Share Posted July 14, 2011 mine has 17cm jbl 3 ways in the rear they only need a slight trim to the trims, and 10cm in the front they go straight in no mods other than to change the crimps Quote Link to comment Share on other sites More sharing options...
sutty_32 Posted July 14, 2011 Share Posted July 14, 2011 got standard size 4 inch in the front, and put 6x9's in the back. They needed a spacer and the trim cutting to fit. My back door sub was also broken so just put a standalond sub/box/amp combo off ebay for £40. It all sounds pretty good with a decent head unit and will go loud enough to drown out the squeaks, rattles and tyres There is an amp in the back door already for the standard sub, so you could use that assuming its still working, but it only works the two sub speakers in the door. Quote Link to comment Share on other sites More sharing options...
Jimbo_C Posted July 15, 2011 Share Posted July 15, 2011 Hi I have got 13cm speaker in the rear of mine, I go the ripspeed ones from halfords, with my trade card they were about 20 quid. The speakers in the rear door only work on standard fit stereos from what I can remember, I seem to recall fitting a low pass filter to the rear speaker wires and then hooking them up directly. Try having a look at the feed going to the amp and chase it back to the stereo loom. it might just need a switch or connecting to the aux power out on an after market. cheers jim Quote Link to comment Share on other sites More sharing options...
tel Posted July 15, 2011 Share Posted July 15, 2011 6x9's are a ok option if you dont have the rear dickie seats as they hit otherwise Quote Link to comment Share on other sites More sharing options...
task Posted July 15, 2011 Share Posted July 15, 2011 I replaced my fronts with some Alpine speakers and the rear with boston acoustics. Both of the same size. I removed the rear door "subs" and replaced them with a boxed 10" run through a separate amp. The whole lot is run from an Alpine ipod head unit. Quote Link to comment Share on other sites More sharing options...
DiscoHere Posted July 17, 2011 Share Posted July 17, 2011 Rear sub (in door) has its own amp attached to it. I have my one working of the RCA output from my Sony head ...no problem and no modifications. The only criticism I would have of it is that it is not very tonal but it does give a good deep bass. Hugh Quote Link to comment Share on other sites More sharing options...
Phil B Posted July 18, 2011 Author Share Posted July 18, 2011 Yeah my rear subs are shot so I might buy some components minus the tweeters to do that job and run a phono out to it once I've assessed it all Quote Link to comment Share on other sites More sharing options...
pw8757 Posted July 21, 2011 Share Posted July 21, 2011 I would always recommend a look at Dabonwheels....... Quote Link to comment Share on other sites More sharing options...
