mad4mud33 Posted July 19, 2011 Share Posted July 19, 2011 hello i have the body off my 98 300tdi disco and i was wondering if i was to put a 2" body lift in would i be able to run with 265/75/16 tyres with standard height suspension and the arches cut Quote Link to comment Share on other sites More sharing options...
p76rangie Posted July 20, 2011 Share Posted July 20, 2011 Probably better fitting 235/85/16 as they a couple of mm taller but not wide enough to cause too many issues hitting the inside or outside of the inner guard. I would think that 265 tyres would also be getting a bit wide for standard width rims. You will have to do a "camel cut" to the lower rear wheel arch still. Here are my Rangie 235/85/16 tyres fitted to my wifes D1 with no lift, but a camel cut in the rear Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 20, 2011 Share Posted July 20, 2011 What I say below is about a 1990 RRC, but would probably be relevant at least to a degree... I run 235x85s and when I first fitted them there were two problems - first they hit the outside edge of the wheel arch (front and back) - so I trimmed those back; and second they hit under the inner wheel arch at the rear, so I decided to do a body lift. After much measuring and thinking I went for a 30mm lift - details here - and got lucky. Now nothing fouls and (IMHO) it looks just right. With regard to 275 tyres, they are a little less tall so clearance under the arches would't be a problem once you have the lift, however having looked at my tyres when fitted I believe that 275s would protrude beyond the standard body and would therefore need some kind of spat or arch extension. Hope this helps. Roger Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 20, 2011 Share Posted July 20, 2011 I would think that 265 tyres would also be getting a bit wide for standard width rims. All Discovery rims are 7x16 and 265/75R16 are fine on those. Quote Link to comment Share on other sites More sharing options...
Phil B Posted July 20, 2011 Share Posted July 20, 2011 Mine came with 265, binned them off for STD 235 insa dakars, as the rubbed and cut themselves with a 2inch lift and spacers, I'd say a suspension lift would be better than a body lift for articulation purposes and the only prob id find with my STD Tyres would be in bombpits I should imagine with diff clearance Quote Link to comment Share on other sites More sharing options...
mad4mud33 Posted July 20, 2011 Author Share Posted July 20, 2011 What I say below is about a 1990 RRC, but would probably be relevant at least to a degree... I run 235x85s and when I first fitted them there were two problems - first they hit the outside edge of the wheel arch (front and back) - so I trimmed those back; and second they hit under the inner wheel arch at the rear, so I decided to do a body lift. After much measuring and thinking I went for a 30mm lift - details here - and got lucky. Now nothing fouls and (IMHO) it looks just right. With regard to 275 tyres, they are a little less tall so clearance under the arches would't be a problem once you have the lift, however having looked at my tyres when fitted I believe that 275s would protrude beyond the standard body and would therefore need some kind of spat or arch extension. Hope this helps. Roger thanks for the info and im thinking of using defender arches over the arches Quote Link to comment Share on other sites More sharing options...
p76rangie Posted July 20, 2011 Share Posted July 20, 2011 I'd say a suspension lift would be better than a body lift for articulation purposes Can you explain? Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted July 20, 2011 Share Posted July 20, 2011 I'd have said the opposite, the rear trailing link bushes will only go so far and the geometry gets scrwwed up with a lift, both front and rear, plus the propshafts have to work harder. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 22, 2011 Share Posted July 22, 2011 thanks for the info and im thinking of using defender arches over the arches Keep us informed... With photos if poss... I would like to know if it's an easy job cos if it is then I might do it too. Quote Link to comment Share on other sites More sharing options...
