Dorset Cocker Posted August 14, 2011 Share Posted August 14, 2011 Hi all, just wondered if anyone can help. I think I have an electrical short somewhere on the light circuit of my Defender 90, as when I'm driving and have the lights on, the radio goes on and off. The lights also flicker on and off when I go over bumps. Can anyone tell me if there is any common areas to check or am I going to have to check all the wires? Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2011 Share Posted August 14, 2011 have a look at the front lights wiring as it goes from the bulkhead to the front lights along the top of the inner arches, it may have worn through the insulation by chaffing on the arch. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted August 14, 2011 Share Posted August 14, 2011 Welcome to LR4x4.......... can't helo you with your light problem, but you may wish to check out www.dorsetrover.co.uk if you're not already a member...! Ron. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 15, 2011 Share Posted August 15, 2011 Often when more than one thing is affected it's a bad earth - check your earth straps & follow the black wires to where they all meet at the body/chassis. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 15, 2011 Share Posted August 15, 2011 Often when more than one thing is affected it's a bad earth - check your earth straps & follow the black wires to where they all meet at the body/chassis. i have just had all of my dash off and there was no main earth for the wiring loom, i had a simaler problem but my heater light came on nothing worked but if it went out things came back on my problem was the earth on the starter motor and i have now made a new earth for the loom as well i now have a new problem that my indicators work with out the ignishion on but i can live with that. unless any one can point me in the right direction Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 15, 2011 Share Posted August 15, 2011 There is a big bundle of earths on the engine side of the bulkhead near the clutch master cylinder. Make sure that these are all clean and tight and then that the bulkhead is well earthed to the battery -ve. This particular collection of earth wires seem to cause a whole lot of headaches. Chris Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 15, 2011 Share Posted August 15, 2011 i have just had all of my dash off and there was no main earth for the wiring loom, i had a simaler problem but my heater light came on nothing worked but if it went out things came back on my problem was the earth on the starter motor and i have now made a new earth for the loom as well i now have a new problem that my indicators work with out the ignishion on but i can live with that. unless any one can point me in the right direction indicators now fixed a new hazared switch fix that There is a big bundle of earths on the engine side of the bulkhead near the clutch master cylinder. Make sure that these are all clean and tight and then that the bulkhead is well earthed to the battery -ve. This particular collection of earth wires seem to cause a whole lot of headaches. Chris theres was only one wire there, i have also run a new earth from the loom to the main earth on gearbox Quote Link to comment Share on other sites More sharing options...
Dorset Cocker Posted August 27, 2011 Author Share Posted August 27, 2011 Thank you everyone for your replies, just off to have a look now. thanks again. Quote Link to comment Share on other sites More sharing options...
