Astro_Al Posted August 24, 2011 Share Posted August 24, 2011 Hi guys, well, not long after my head gasket / radiator etc etc swap, I was towing a trailer a few hours ago when I heard a bit of a funny noise - like a gear grinding or something (not changing gear, just cruising), so I got out to have a look - nothing. Figured it could have been just the usual trailer rumbles and jolts. then I noticed water dripping fast onto the ground from the engine to gearbox bellhousing mating. It is running down the nearside / rear face of the engine from somewhere I can't see. Is this likely to be my new heat gasket (already?!), or the rear core plug (the only one I didn't replace) leaking? The engine didn't overheat - had hardly gone anywhere. Any tips to aid diagnosis - I can't get in there enough to see where its coming from. If it is the core plug, is there a nice easy way to get to it - drill through bulkhead from the cabin? Cheers, Al. Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted August 25, 2011 Share Posted August 25, 2011 Sounds like a core plug. Is it a 200/300Tdi engine? Same thing happened to me. The core plug was corroded because some muppet had been running it with no antifreeze and when the system pressurised when the head cracked, it forced water out of the core plug. Not an easy job either, engine out time. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 25, 2011 Share Posted August 25, 2011 I agree - one core plug on the back of the head. I've replaced one in situ, but it's a bugger to do. Worth it though - considering you would otherwise have to remove the head again. Les. Quote Link to comment Share on other sites More sharing options...
moose Posted August 25, 2011 Share Posted August 25, 2011 If its a 300 check the heater pipes.. one of them is very prone to rub through on the back of the engine. Quote Link to comment Share on other sites More sharing options...
