Mr Bean Posted August 24, 2011 Share Posted August 24, 2011 I have finally got round to removing the old engine (fantastic hole in the side!!!) and fitting the 2.25 5 bearing engine i had. I have found that this engine is also metric where the old one was imperial. So i bought a new dipstick from paddocks which was labelled as metric but it doesn't fit, the old doesn't fit either!!! Is there a third size of dipstick i need? Any ideas guys? Thanks Trev Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 24, 2011 Share Posted August 24, 2011 In what way do they not fit, too large, too small, wrong pitch thread? Do you have a vernier to measure the bore of the hole...might be able to identify it remotely! How come it came without a dipstick?! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 25, 2011 Share Posted August 25, 2011 In what way do they not fit, too large, too small, wrong pitch thread? Do you have a vernier to measure the bore of the hole...might be able to identify it remotely! How come it came without a dipstick?! Hang on a minute? Couldn't you use the old dipstick in the new tube? Or was there no retaining nut on the new engine? Sounds odd. The tubes are interchangable, I'm using a 3 bearing tube and stick on a tdi200 block. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted August 25, 2011 Author Share Posted August 25, 2011 The issue is not with the tubes but with the nuts on the tube. The 5 bearing engine i bought did not have one in it but when i thought i could use the old one, but that does not fit either. So i bought a new tube and lock nut which is a similar diameter as the old one but a very coarse pitch, the old one was a very fine pitch. I think i will have to do some measuring, i was just curious if someone knew what the two different threads are off the top of their head. Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted August 29, 2011 Author Share Posted August 29, 2011 I guess no one knows.... Quote Link to comment Share on other sites More sharing options...
oscar03 Posted September 16, 2011 Share Posted September 16, 2011 double check the one you bought new is actually correct. it wouldnt be the first time something has been labeled incorrectly. Quote Link to comment Share on other sites More sharing options...
