dirtyninety Posted August 27, 2011 Share Posted August 27, 2011 Wondering what oil cooler to fit to my autobox, The original disco cooler is the wrong shape to fit in my challenge truck. Also, what thread does the auto box have, M18 male or M16 male (or female i forget)? Looking at Mocal oil coolers there a lots of different capacities. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 27, 2011 Share Posted August 27, 2011 There are two sizes as they have a male to male reducer (the standard pipe connection is larger than the thread into the box) on them. From measuring the reducer you will either need a m20 fine (1.5) female connection to go on the reducer or if you do as I did and replace the reducer then you will need a M16 fine (1.5) male. I replaced the reducers to convert them in to -8JIC connectors. I just took the reducers to ThinkAuto and had them match it. Edit Found offline copy of PDF (as their web site seem broken) and I bought 2 MMS2-8-65 -8JIC x M16x1.5 to replace the reducers Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted August 27, 2011 Author Share Posted August 27, 2011 Excellent, i was reading on some forums that there are "old" and "new" auto box's, older ones used a m16 and newer ones use a m18 (or the other way around) it didnt mention when the old type ended and what year new type started! My autobox is out of a 200tdi discovery, what year i don't know, as i only purchased the box. Also, would i be able to use "push on" connections and jubilee clips or does the auto-box oil pump produce to much pressure? Quote Link to comment Share on other sites More sharing options...
Team Idris Posted August 27, 2011 Share Posted August 27, 2011 I popped rubber hose onto the steel tubes. There was surface rust so I reconed I'd get away without the ribbed pipe ends. And as far as we know, the non-electronic ZF4 we have is on a bypass. Then we used a 16 'oxford' style oil cooler. (the ones they sell as engine coolers). Quote Link to comment Share on other sites More sharing options...
zardos Posted August 27, 2011 Share Posted August 27, 2011 My Auto box is in a 1996 3.9 V8 discovery, if that helps. And Think Auto said that AGP socketless was OK for gearbox oil and is rated to 250psi and 150C with push fit and no jubilee clip. Quote Link to comment Share on other sites More sharing options...
zardos Posted August 27, 2011 Share Posted August 27, 2011 And out is on the side of the box after it has done it's work and the hottest, in is on the bottom of the box and is just a return to sump. So it should not be very high pressure. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted August 27, 2011 Author Share Posted August 27, 2011 Thanks Zardos, I'll order up some parts off thinkauto now! Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted August 30, 2011 Share Posted August 30, 2011 Ashcroft's advised me that the oil runs the other way round when the torque converter locks up, I aksed because I was thinking of adding an in line filter on my new 'box. If I understand correctly they also advise the P38 had M18 unions, the RRC had M16 unions. I'm not sure if all boxs swapped over in 1995/6 or not though. There's advice on their website. Quote Link to comment Share on other sites More sharing options...
