ashtray Posted August 29, 2011 Share Posted August 29, 2011 Hello chaps. Got a gearbox rattle from my 03 90 td5. I've had the rattle a long time now and it hasn't got any worse, just got more on my tits. But I can't find it!! It happens at high revs in all gears, I can't tell you the exact revs but at 60-65mph in 5th is where it really gets on song. At 70 the car is massively quieter. I can also get the rattle in neutral by revving hard. It seems to come from the tunnel area and is a tinny metallic rattle. The propshafts are spot on before I get a telling off for not greasing them, I have learnt my lessons from lack of propshafts husbandry.. I have no other rattles, the car has done 73k miles now. I cannot reduce the rattle in any way by wrestling with either of the gear levers. And it does it with the clutch down. Any ideas? Many thanks! Quote Link to comment Share on other sites More sharing options...
dickydutch Posted August 30, 2011 Share Posted August 30, 2011 I had this noise and initially felt sure it was coming from the gearbox area. However, ive since realised it comes from the handles that you control the ventilation flaps with! Sorry if this sounds daft but got to be worth a look? Quote Link to comment Share on other sites More sharing options...
ashtray Posted August 30, 2011 Author Share Posted August 30, 2011 I know what u mean, it does sound similar, if only it was that noise, what a simple fix that would be! Quote Link to comment Share on other sites More sharing options...
ashtray Posted August 30, 2011 Author Share Posted August 30, 2011 Well I've spent the best part of an evening randomly poking and pulling on things underneath, and I can't find anything really standing out, apart from the flexible joint in the down pipe creaks when bent. I can't get the cat to rattle by hitting it but do u reckon this could be the noise? It's a very harmonic tinny rattle, and it happens almost precisely at high revs, doesn't necessarily need to be under load but is more apparent when going up through the gears. It sounds like gears rattling to me, almost like the clutch bearing is chattering? But it does it even with the clutch down Cheers Ash Quote Link to comment Share on other sites More sharing options...
DNH Posted March 2, 2012 Share Posted March 2, 2012 Hi Ash - I just found your post and it sounds almost identical to the latest rattle that my 2003 TD5 90 has recently. Did you ever findout what was causing the rattle or have you resorted to the time honoured tradition of turning the radio up? Quote Link to comment Share on other sites More sharing options...
demito Posted March 16, 2012 Share Posted March 16, 2012 Hi, I am curious to learn about any solution to this irritating vibration. Mine is a 110 TD5 SW and does exactly the same. Quote Link to comment Share on other sites More sharing options...
Lorrick Posted March 16, 2012 Share Posted March 16, 2012 Hi Ash, Its the same on my TD5 2002 Utility wagon, rattles like mad when your up in hi revs , change gear and all is well, Have been told some do some don't ? If you find an answer please let me know Quote Link to comment Share on other sites More sharing options...
Tractorboy596 Posted May 29, 2020 Share Posted May 29, 2020 Hi there, I have found this thread after searching for a identical problem on the same 2004 td5, did you ever come to a conclusion? Thanks Quote Link to comment Share on other sites More sharing options...
ALWOO Posted October 31, 2021 Share Posted October 31, 2021 Had the high pitch bell sound that is described above, Just thought i would write in to say what it was. (disco 2 TD5) There's a kind of steering stabilizer shock absorber between the two front wheels. There is a metal cover on that shock that was loose and ringing when revs were high. Quote Link to comment Share on other sites More sharing options...
Landrovernuts Posted November 1, 2021 Share Posted November 1, 2021 As already mentioned try the vibration dampers. If they are not the issue, the handbrake mechanism can rattle (including the shoes against the backplate if not assembled correctly) and exhaust silencers can rattle. The front exhaust flexi can also make funny noises but I wouldn’t say it was a rattle! Good luck! Toby Quote Link to comment Share on other sites More sharing options...
