Dave K Posted September 12, 2011 Share Posted September 12, 2011 I'm looking for details on ESR3133, Defender fuel pipe, Sender-(tank) to lift pump. Are there any other numbers for it, or alternatives? Quote Link to comment Share on other sites More sharing options...
western Posted September 12, 2011 Share Posted September 12, 2011 probably easier & cheaper to buy a suitable length of nylon diesel piping from a diesel injectoin place or nearest motor factors, you can swap the end fittings over they are only screwed into the nylon pipe IIRC. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 12, 2011 Share Posted September 12, 2011 That number supercedes: ESR1573 If that helps Quote Link to comment Share on other sites More sharing options...
Dave K Posted September 12, 2011 Author Share Posted September 12, 2011 probably easier & cheaper to buy a suitable length of nylon diesel piping from a diesel injectoin place or nearest motor factors, you can swap the end fittings over they are only screwed into the nylon pipe IIRC. I've a piece of solvent proof nylon clear pipe that might work (9mm- i.d.) Quote Link to comment Share on other sites More sharing options...
western Posted September 12, 2011 Share Posted September 12, 2011 item 1 on this page from my microcat. hth. couldn't upload this earlier as my scanner decided to throw a wobbly, Quote Link to comment Share on other sites More sharing options...
Dave K Posted October 7, 2011 Author Share Posted October 7, 2011 Just to conclude this thread, it turned out to be the Fuel Injection Pump. Wallet is still smarting It only took new fuel lines, 2 lift pumps, 3 filters to find Quote Link to comment Share on other sites More sharing options...
