Baz2236 Posted October 11, 2011 Share Posted October 11, 2011 Hi I am getting some strange vibrations through the t-box / gear box. I have very soft rubber mounts so I have ordered some new ones. My question is can I change the mounts whilst the box is all in place. Can I put a jack under and lift it off the mounts. Thanks in advance. Baz Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 11, 2011 Share Posted October 11, 2011 Yep. Dont lift the box off though, just unbolt the mounts one at a time from the chassis, drop them down, change the rubber and bolt back up. I support the transfer box with a jack when i do this, but i think it probably rests fine for a short while on the other mount without the jack. Quote Link to comment Share on other sites More sharing options...
western Posted October 11, 2011 Share Posted October 11, 2011 as above support the TB & unbolt the chassis part of the mount, 3 long bolts/nuts per side & the cemtral nuts on top/bottom of rubber mount, should be no need to move the TB part of the mounting Quote Link to comment Share on other sites More sharing options...
ashtray Posted October 13, 2011 Share Posted October 13, 2011 Is there any definitive way of testing these mounts are worn out, my 90 is very vibey, much more so than my mates 55plate. mine is an '03 90 with 76k. Whats the average life expectancy of these in miles/age? Thankyou Ash Quote Link to comment Share on other sites More sharing options...
