PS_Bond Posted October 18, 2011 Share Posted October 18, 2011 Daft question... Are all the fasteners holding the flywheel housing & bell housing together supposed to be studs into the flywheel housing? Or are any of them supposed to be bolts? Looking at Microcat, I can see an M10x30 bolt, and M10x35 bolt and an M10x25 stud - but I'm not sure which is supposed to be where... TIA Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2011 Share Posted October 18, 2011 page 245 shows 1 stud M10 x 25mm as item 3 & a dashed line going to it's location on the flywheel housing left side hth. Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted October 18, 2011 Share Posted October 18, 2011 Hiya There are 4 bolts on the underside (15mm socket). The rest are M10 flange nuts (17mm socket) and studs. Quote Link to comment Share on other sites More sharing options...
PS_Bond Posted October 18, 2011 Author Share Posted October 18, 2011 Many thanks - from the workshop manual I've got 14 fasteners total (step 47, P4, Manual Gearbox Repair); from the parts catalogue (as posted), it lists 13 M10x30 on P245, yet in the gearbox section it claims that it requires 4 M10x110mm, 9 M10 flanged nuts and an M8x14. I could go mad cross-referencing things... Having pulled one engine & got a lot of the way through putting this one back, I've got an awful lot of left-over bolts. Not ideal. Quote Link to comment Share on other sites More sharing options...
