Tex Gore Posted October 19, 2011 Share Posted October 19, 2011 Hi, I think the clutch might be going on my 2005 TD4 but sincerely hoping someone can suggest something else. Symptoms are: Engine 'races' whilst on the move if I put foot down - over about 2000 revs the rev counter just flies around the dial Do the above for more than a couple of seconds and there's a nasty clutch smell Not pulling away cleanly, although it is drivable by building up speed slowly and keeping out of power-band territory Apply handbrake and try and pull away in 2nd/3rd and it does strain against the brake then stall It goes in and out of gear fine Have tried pumping the clutch/letting it come back up hard in case there was some stickiness going on to no avail. Is this the clutch then, or could there be easier things to check? Anyone done an FL1 clutch - what's it like to do? Quote Link to comment Share on other sites More sharing options...
EggNChips Posted October 19, 2011 Share Posted October 19, 2011 If it quack's like a duck and waddles............Clutch I'm afraid. not that much different to a FWD car, with the exception of the IRD box has to come off as well. Adds a few hours onto the job Quote Link to comment Share on other sites More sharing options...
reb78 Posted October 19, 2011 Share Posted October 19, 2011 Tex. The rave manuals are linked to in the tech archive on here. Should have info for changing the clutch in there. Quote Link to comment Share on other sites More sharing options...
marty1a Posted October 19, 2011 Share Posted October 19, 2011 I did a clutch on the fl1 back in july but it was a 1.8 petrol - around 6 hrs as I lifted the engine out, new timing belt, water pump etc.. was done while it was out :-) Quote Link to comment Share on other sites More sharing options...
EggNChips Posted October 20, 2011 Share Posted October 20, 2011 I did a clutch on the fl1 back in july but it was a 1.8 petrol - around 6 hrs as I lifted the engine out, new timing belt, water pump etc.. was done while it was out :-) You did well doing it in 6hrs!!! Quote Link to comment Share on other sites More sharing options...
marty1a Posted October 20, 2011 Share Posted October 20, 2011 Engine crane & load leveller are the best two investments :-) Quote Link to comment Share on other sites More sharing options...
Tex Gore Posted October 20, 2011 Author Share Posted October 20, 2011 A very kind gentleman has loaned me a transmission jack. Day one went well, anyway. Quote Link to comment Share on other sites More sharing options...
bradburygroup Posted October 22, 2011 Share Posted October 22, 2011 Ive came across 2 freelanders where the clutch fork was seized / tight causing the clutch not to release fully causing slip and eventually total failure, check to seek if you can move the clutch lever towards the slave cylinder Quote Link to comment Share on other sites More sharing options...
Tex Gore Posted October 24, 2011 Author Share Posted October 24, 2011 Ive came across 2 freelanders where the clutch fork was seized / tight causing the clutch not to release fully causing slip and eventually total failure, check to seek if you can move the clutch lever towards the slave cylinder It has a concentric slave cylinder - no fork. We replaced the slave cylinder when we did the clutch. Quote Link to comment Share on other sites More sharing options...
