AALPHA2011 Posted November 18, 2011 Share Posted November 18, 2011 Hi all. I have been trying to get a back box on my Freelander td4 diesel September 2001 to 2006 type. The box I have on now has two pipes coming from it. Everytime I ask for the part I require, they tell me that only one pipe is needed. If mine has two, wont it alter the power or performance in some way if only one exit pipe is put on??? Not sure where to go on this one and I am sure that its obvious? Thanks Phil Quote Link to comment Share on other sites More sharing options...
gary1968 Posted November 20, 2011 Share Posted November 20, 2011 Are you sure the one that is fitted is indeed the correct one?? I think the V6 back box has 2 tail pipes, not heard of any others having that..... Gaz Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 20, 2011 Share Posted November 20, 2011 It's only a box with a hole in - two pipes or one makes little odds, it's not an F1 car. Quote Link to comment Share on other sites More sharing options...
AALPHA2011 Posted November 20, 2011 Author Share Posted November 20, 2011 It makes a difference when the box with one pipe has the wromg length and the wrong circumference to fit??????? Quote Link to comment Share on other sites More sharing options...
LR NUT Posted November 20, 2011 Share Posted November 20, 2011 It's only a box with a hole in - two pipes or one makes little odds, it's not an F1 car. I drive mine like an F1 car FridgeFreezer haha Quote Link to comment Share on other sites More sharing options...
AALPHA2011 Posted November 20, 2011 Author Share Posted November 20, 2011 LOLLOLOL Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 21, 2011 Share Posted November 21, 2011 It makes a difference when the box with one pipe has the wromg length and the wrong circumference to fit??????? That wasn't what you said, your original post said it was the tail pipes that are different. if it's being sold as a suitable fit then there should be no problem. Quote Link to comment Share on other sites More sharing options...
nickcc Posted November 21, 2011 Share Posted November 21, 2011 My 2005 TD4 also has the box with two tail pipes, I was told by my LR dealer that either were suitable and it all depended on the stock level LR held when the car was made. Quote Link to comment Share on other sites More sharing options...
AALPHA2011 Posted November 21, 2011 Author Share Posted November 21, 2011 After me nearly going around the bend and not being clear enough to you guys, I now have the V6 box fitted to my TD4 2L Diesel. Sorry if I confused anyone. Apparently Nick, you are correct, they did just that on the 2001 and after. The twin tail piped boxes were fitted to the TD4 and not only the V6. The single tail pipe one is to small in circumference if you have the twin pipe system. Thanks for all the answers though, its appreciated. Phil Quote Link to comment Share on other sites More sharing options...
