jagwit Posted November 23, 2011 Share Posted November 23, 2011 Hi Does anyone know if its possible to lower the torque convertor lock-up speed? If so, how? Mine locks at about 80km/h but I would like to lower that to around 60km/h. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 23, 2011 Share Posted November 23, 2011 You'd find it struggling to pull at those engine revs TBH, I would leave it as is it, and IIRC it's a box modification to change anyways. 53mph is the book speed, so 80kmh isn;t far out at all, allowing for speedo innaccuracies. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 23, 2011 Share Posted November 23, 2011 Depending on your intended use of said vehicle, and your tyre size, changing the transfer gear ratio may be an option. If you just use it on the road with standard tyres, just stick with it how it is. Quote Link to comment Share on other sites More sharing options...
jagwit Posted November 24, 2011 Author Share Posted November 24, 2011 I was hoping it would be a relatively simple change like replacing a spring or two here and there. The car is 100% standard down to tyres and will be used mainly in town with the occasional open road trip. Even in town there is enough torque to lock the convertor in 4th IMHO. Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 24, 2011 Share Posted November 24, 2011 It won't be good for the 'box or the engine. My LSE is a 5.0l and has plenty of torque but i still wouldn't want it locking up as low as 60KPH, 75 perhaps as many roads round here are a 50mph limit (80Kph) and it's not quite fast enough for the TC to lock up. AFAIK it's a serious rebuild of the gearbox to acheiev this, you would need all the gearshift points moving down to acomodate it for a start. Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted November 26, 2011 Share Posted November 26, 2011 I asked Ashcrofts about this as my irritation is the 50 limits,I wanted to get the lockup in at 48mph on my D1 tdi which would happily pull it.Their answer was that it would require a spring to be shortened - but the amount would be trial and error and its well inside the box.Shame really,that its not worth doing. Quote Link to comment Share on other sites More sharing options...
jagwit Posted November 26, 2011 Author Share Posted November 26, 2011 Now if we just find out WHICH spring and HOW DEEP its into the box... Quote Link to comment Share on other sites More sharing options...
Range Rover Blues Posted November 27, 2011 Share Posted November 27, 2011 I never thought to ask whilst they had mine apart, but I do know it's trial and error because the 'box works on pressure settings. I'll just keep telling myself it would knock the bottom end out of my engine. Quote Link to comment Share on other sites More sharing options...
