ejparrott Posted December 4, 2011 Share Posted December 4, 2011 Hi all, Got a 19J fitted into a friends Series II, which doesn't have servo assissted brakes. Whats the most sensible option for the vacuum pump, seeing as we've no use for 'on-board vacuum'! Shall I pull it and put a blanking plate over the hole, or pop a short length if vacuum hose on the outlet/input with a blank in that? Cheers Quote Link to comment Share on other sites More sharing options...
Briarston Posted December 4, 2011 Share Posted December 4, 2011 Take the vanes out so no vacuum is produced, and plug the outlet hole, perhaps? Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2011 Share Posted December 4, 2011 (edited) see page 154 just remove the vanes as suggested above & blank off the outlet. taking the centre part out might allow the oil pump drive [use the upper end to drive the vacuum pump] to much space to become disengaged with the camshaft. Edited December 4, 2011 by western Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 4, 2011 Share Posted December 4, 2011 Fit the later S3 brake pedal/servo arrangement and have awesome brakes Les. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 5, 2011 Author Share Posted December 5, 2011 Thanks Ralph, I'll have a look at doing that. If it were mine Les then for sure I'd be converting to dual line and a servo before she went back on the road, but she's not, so it's down to the owner and his lack of funds for such an upgrade! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 13, 2011 Author Share Posted December 13, 2011 Take the vanes out so no vacuum is produced, and plug the outlet hole, perhaps? see page 154 just remove the vanes as suggested above & blank off the outlet. done! The inside, for anyone whos not seen it...the four vanes just tipped sideways with a prod from a (clean) screwdrive, then lifted out by hand Quote Link to comment Share on other sites More sharing options...
ejparrott Posted December 17, 2011 Author Share Posted December 17, 2011 Belt and braces job, I've turned a stainless bung, and dropped a short length of silicone vacuum pipe over the connection, just to keep it clean... Quote Link to comment Share on other sites More sharing options...
