rodders Posted January 25, 2012 Share Posted January 25, 2012 this light came on about a month or so ago but not everytime then it went away. came back on this morning. any ideas what is causing it? thanks in advance. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 25, 2012 Share Posted January 25, 2012 Have you checked your handbook? It normally just means a fault has been recorded and needs reading with tool plugged in to it. Quote Link to comment Share on other sites More sharing options...
SimonTemplar Posted February 2, 2012 Share Posted February 2, 2012 This happened to ours a couple of weeks ago. We booked it in, they scanned it, it came up with a few minor faults related to service intervals (it had been serviced but not reset), they cleared it off, then in the hard frost a few days ago it came back. It now flashes when we set off, then goes back to constant. It will sometimes just go out on its own. The garage can't find anything wrong, and they know these cars, so I am wondering if it is just a connection somewhere to the light itself that does not like the cold weather... the car drives perfectly. So if you get any response more substantive than that, I would be an interested reader, too! ST Quote Link to comment Share on other sites More sharing options...
marty1a Posted February 2, 2012 Share Posted February 2, 2012 Rodders, Is it an 1.8K series engine? If yes check the spark plugs - the flashing is random misfire - solid light will properly show a code saying about a weak fuel mix. Are you loosing any coolant?? Quote Link to comment Share on other sites More sharing options...
SimonTemplar Posted February 2, 2012 Share Posted February 2, 2012 Rodders, Is it an 1.8K series engine? If yes check the spark plugs - the flashing is random misfire - solid light will properly show a code saying about a weak fuel mix. Are you loosing any coolant?? Sorry to butt in, but what would coolant loss signify? Mine did this today... Quote Link to comment Share on other sites More sharing options...
SimonTemplar Posted February 3, 2012 Share Posted February 3, 2012 Does anyone have any thoughts on this? Taking the Freelander to the garage this morning, would rather go in armed with an opinion based on more than my own rudimentary knowledge! Quote Link to comment Share on other sites More sharing options...
marty1a Posted February 3, 2012 Share Posted February 3, 2012 If your loosing coolant and light flashing could well be a HGF, water blowing out the spark and upsetting the fuel mix. (I have this problem!! at the min sorting it this wkend) If the light is just flashing and your not loosing coolant coil pack or HT lead or plug id say would be at fault Quote Link to comment Share on other sites More sharing options...
SimonTemplar Posted March 27, 2012 Share Posted March 27, 2012 In case anyone is still interested in this one, we got to the bottom of our yellow warning light issue: when the head gasket failed it swamped and broke the lambda sensor. So even with the head gasket sorted, the sensor still registered a fault. We swapped out the sensor, and no longer have the warning light. ST Quote Link to comment Share on other sites More sharing options...
Wesleyjpearce Posted December 13, 2014 Share Posted December 13, 2014 Hi guys I have a freelander td4 engine light comes on when you boot it if you turn key off it resets and goes out sometimes it dose not come on for days then every time until you reset it three times it goes into limp mode two Quote Link to comment Share on other sites More sharing options...
