pupstew Posted April 10, 2012 Share Posted April 10, 2012 Right so tonight I delved deep inside the dash board top to dig my way to the nut on the back of the front windscreen washer jet with success. Content with my mini win i decided to have a look at the heater controls on the drivers console. The speed control is fine but a little stiff so a touch of lubrication sorted that out. The temperature controller was also spot on and works fine. However that the directional contoller is as much use as a fart in a space suit. The arm moves ish but the control cable slides back and forward through the clamp. I repositioned the clamp and have found that ais on the other end must be seized. So here is the question.......what is on the other end? and how the hell do i get to it easily.... Cheers Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2012 Share Posted April 10, 2012 other end goes to these type clamps http://www.brit-car....php?xProd=91380 photo below see item 15 page 628 http://www.retroanac...ng_p580-666.pdf inside the lower dash page 629 http://www.retroanaconda.com/landrover/parts_books/110/7_exhaust_cooling_heating_p580-666.pdf Quote Link to comment Share on other sites More sharing options...
pupstew Posted April 10, 2012 Author Share Posted April 10, 2012 Is the lower dash easy to get in to? it seems like where the cable gets to the flaps the mechanism might have seized. Is this feasable? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted April 10, 2012 Share Posted April 10, 2012 There's a top cover to it, fastened by a multitude of stupid little screws if I remember correctly. If that comes off you'll be able to get to the mechanism inside. Quote Link to comment Share on other sites More sharing options...
western Posted April 11, 2012 Share Posted April 11, 2012 as said above, loads of philiprs head small screws along the edges. Quote Link to comment Share on other sites More sharing options...
