disco111 Posted April 11, 2012 Share Posted April 11, 2012 Hallo everybody Is there anybody on this forum with a gear set distribution system from Zeus ?? Many years ago I bought one ,and now the timingbelt needs to be changed,but before starting such a big change I would like to hear if there are some members with this gear set running on the Discovery. The work itself is not the problem because I am a mechanic and I work on engines on a daily basis.The question is:is this system reliable,and what's the noise level of the gears when ideling ??? Discovery 1 year 1990 chassis :GA series Many greetings Martin Gent Belgium Quote Link to comment Share on other sites More sharing options...
barriesheene Posted April 16, 2012 Share Posted April 16, 2012 Sorry Martin cant help but I hope somebody comes along soon who can. Quote Link to comment Share on other sites More sharing options...
fozsug Posted April 16, 2012 Share Posted April 16, 2012 Im sure i have seen this discused on here somewhere but cant seem to find it! Here you go http://forums.lr4x4.com/index.php?showtopic=14746 http://www.landyzone.co.uk/lz/f8/timing-gears-tdi-engine-51320.html http://www.horizonsunlimited.com/hubb/4wd-overland-tech/zeus-timing-gears-25501 http://forums.lr4x4.com/index.php?showtopic=52723 Quote Link to comment Share on other sites More sharing options...
western Posted April 16, 2012 Share Posted April 16, 2012 I used to have a set of timing gears in my Defender 200Tdi, took them off & went back to the timing belt, much quieter. Quote Link to comment Share on other sites More sharing options...
disco111 Posted April 21, 2012 Author Share Posted April 21, 2012 Hallo guy's First of all many thanks for the replay's on my topic. I have seen most of the comments on the timing gears,one thing is for shure they are verry noisy, and most off the people who installed them where not happy,some ended up in an engine dissaster. There is a splitted gear in the set to prevent backlash between the gears did they respected the tension of the spring in the pignon?normally their there sould be no noise on idling ?? Thats strange,because I am working on wheel loaders now for at least 25 years and most of them are equiped with Kubota engines with gear distribution system and what's more we never had one fault on the distribution system.Most of the engines died with a totally blokked air filter or with a leak on the filterhousing.(terrible working conditions in demolition situations). I have never seen any wear on the gears an what surprices me is that their made of a soft material and not hardened at all.Those gears have no backlash system and I can't hear them running. My conclusion is :not to install them on my 200TDI Disco for daily use but to install them on the engine of a disco 200 TDI wich I bought for spare parts.The engine is still in a good condition. So we will see how it will end. Until later. Thanks again Martin De Smet Gent Belgium Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 22, 2012 Share Posted April 22, 2012 Don't install them as they are completely carp. Just forget it and stick to the rubber belts. The gears are badly made and don't last 5 minutes. If they were better made it might be a proposition but ..... If you search the forums on Zeus gears you will find many answers to this question. (All negative) Quote Link to comment Share on other sites More sharing options...
