mcc1979ian Posted June 19, 2012 Share Posted June 19, 2012 im in need of a new wing for the 90 but cant seem to find a new aluminium one, instead all i can find is abs plastic panels, whilst rebuilding im gona do both wings as the other aint too great either, just wonderin if anyone has used the abs plastic wings and what your opinions were on them Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted June 19, 2012 Share Posted June 19, 2012 These guys sell aluminium wing panels: http://www.ebay.co.uk/itm/Land-Rover-LH-Defender-Outer-Front-Wing-300tdi-94-98-/261048940353?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cc7bab741#ht_1915wt_1344 Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 19, 2012 Author Share Posted June 19, 2012 had at look at the link £79.99 + £8.99 postage, its a bit much for me, that makes £170 for 2 wings Quote Link to comment Share on other sites More sharing options...
gruntus Posted June 20, 2012 Share Posted June 20, 2012 Hello Ian, I bought mine from Paddocks, they look good and paint fine. The only issue I had was alignment of the securing holes to the wing tops and inner wings. Essenitally I had to open up the holes on the wing tops to get them to fit corrrectly and faff around with the inner wing lip holes. This may be down to my complete strip down and rebuild and a few things being out of kilter but something to bear in mind. I also had to drill new holes for the the wing vents when fitting genuine LR items. But it does mean I will never suffer from corrosion hence the reason for fitting them in the first place! HTH G Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 20, 2012 Author Share Posted June 20, 2012 excellent theory, has to be better as fitting aluminium panels at £79.99 a pop and having to replace them again in the future coz of corrosion or dents and at least plastic dosent really dent so theres no worries on that, may just go ring paddocks and order a pair. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted June 20, 2012 Share Posted June 20, 2012 Do report how you get on if you do - spread the news (good or bad) so others may benefit. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 20, 2012 Author Share Posted June 20, 2012 will do Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 25, 2012 Author Share Posted June 25, 2012 ok so tonite i got the passenger side plastic wing fitted and as mentioned earlier you have to do a little fiddling with the holesto get them to fit, but now its on it looks ideal except for where it meets the bulkhead it starts to bend instead of pulling flush to the bulkhead, im sure with a bit of persistence i will get this sorted out, and get on with the driver side tommorrow. but on the plus they are excellent quality. Quote Link to comment Share on other sites More sharing options...
