defender dinky Posted July 17, 2012 Share Posted July 17, 2012 hi, has anyone done a 200tdi engine and gearbox conversion from a disco 1 to a defender 90 td, i have done this and wondering which engine mounts i should have used, dsco or td, the ones that bolt to engine, i moved the chassis mounts, just wondering about engine mounts, dd Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted July 17, 2012 Share Posted July 17, 2012 i used the mounts from the defender td, rubber mount in between and it slots straight to the chassis mounts Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 17, 2012 Author Share Posted July 17, 2012 i used the mounts from the defender td, rubber mount in between and it slots straight to the chassis mounts i used the ones off disco, and wondering if engine is sitting to low or high ? have nothing to compare it with, dd Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted July 17, 2012 Share Posted July 17, 2012 Disco mounts are IMHO better because they're captive. They should put the engine in the same postion as defender mounts. You have taken the gearbox out the discovery aswell as the engine? If yes your rear prop and gearstick will cause problems or your engine will be very far forward. Your best to use the defender gearbox, especially in a 90. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted July 17, 2012 Author Share Posted July 17, 2012 Disco mounts are IMHO better because they're captive. They should put the engine in the same postion as defender mounts. You have taken the gearbox out the discovery aswell as the engine? If yes your rear prop and gearstick will cause problems or your engine will be very far forward. Your best to use the defender gearbox, especially in a 90. hi, the gearbox is set further back, and i had to cut a little out of the seat box, and designed my own cubby box, Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 17, 2012 Share Posted July 17, 2012 dinky, as long as the engine and box are sitting level, and dont foul anything like the prop or front axle, even on full suspension compression, then it is fine. the disco mounts tend to be smoother aswell. Quote Link to comment Share on other sites More sharing options...
